Wires slapping inside the mast
Posted by Mike Kovacic (sailslakemichigan@…>)
Greetings Fellow Freedom Owners!
I have a 36 with a platform extension (Refuge, White Lake on Lake Michigan). I love the boat and have sailed from Cedar Point in Lake Erie to Muskegon in Lake Michigan with visits to many points in between including the North Channel. The boat has preformed well in all types of conditions. We do have one annoyance however, and that is the slapping of the wires that run to the anchor light, wind instrument and anntenna through the inside of the mast. I tried using a series of foam wedges fastened on a 2X2 that I pushed up maybe 12 feet or so into the mast when it was down for winter storage. My thinking was that if the wires were tight inside the mast that is in the cabin this would reduce the noise in the forward bunk. But alas, this did not work. I was just wondering if anyone else has this problem. When we are in a quiet anchorage, it is great, but the minute we get the slightest wave action, they start slapping. I
suppose we could try sleeping in the aft bunk, but we have always used the v-bunk on all the boats we have owned since the mid-eighties…
Your thoughts would be appreciated.
Mike
Do you Yahoo!?
Y! Messenger - Communicate in real time. Download now.
The simplest but least elegant cure is to hoist a series of lumps of
foam tied to a thin line into your mast. Use one of the halyards to
get this line through the mast. If you’re at it: pull up another
line as a leader in case you want to pull up extra wiring.
good luck.
— In freedomyachts2003@yahoogroups.com, Mike Kovacic
slapping. I suppose we could try sleeping in the aft bunk, but we
have
mid-eighties…
Mike
Do you Yahoo!?
Posted by lemonsbgi (sklklemon@…>)
Depends on how much work you choose to invest. On our 40/40, when the
mast was out for cross country transport, I had a conduit installed
inside the mast. This takes some time and effort, but the wires are
totally quiet. We used gray PVC electrical conduit. This has slip
joints between the 10’ pieces. Don’t glue the joints so it can flex
with the mast. Once the pieces are assembled, they can be pop riveted
inside the mast. This requires two SMALL drill holes about every 5 to
7 feet, one for the rivet and one for the holder. The holder hole is
then filled with epoxy. After pulling the wires, don’t forget to
leave a pull string for any future additions. So far (4 years since
installation) everything has been silent. Steve Lemon
have
mid-eighties…
Mike
Do you Yahoo!?
Wire Slap!
I have done 3 freedoms using cable ties on the wire bundle every 6 feet. I lace the cable ties one into the next to make a three element star. Use long ones like 12 in. or more and that have some stiffness and do not trim them. As they go in, they will bend and that is desired. Make sure that the star is tight on the cable bundle or they will slip.
This arrangement does not interfere with the halyards or running new halyards if one backs out.
One other thing I do is remove the heavy gray multi-conductor cable Freedom used for the masthead lights and replace it with surplus aircraft multi-conductor cable of the same wire size. Aircraft wire is less then half the weight of the gray stuff and is tinned as marine wiring should be.
If you are going to re-install the gray cable, maybe putting the cable ties at 3 of 4 foot would help deal with the added weight of that cable.
Brian Guptil http://www.brigup.com206-818-3203 sailordude@…1735 112th Ave. N.E.Bellevue, WA. 98004-3706
Sent: Monday, September 20, 2004 1:54 PM
Subject: [freedomyachts2003] Wires slapping inside the mast
I have a 36 with a platform extension (Refuge, White Lake on Lake Michigan). I love the boat and have sailed from Cedar Point in Lake Erie to Muskegon in Lake Michigan with visits to many points in between including the North Channel. The boat has preformed well in all types of conditions. We do have one annoyance however, and that is the slapping of the wires that run to the anchor light, wind instrument and anntenna through the inside of the mast. I tried using a series of foam wedges fastened on a 2X2 that I pushed up maybe 12 feet or so into the mast when it was down for winter storage. My thinking was that if the wires were tight inside the mast that is in the cabin this would reduce the noise in the forward bunk. But alas, this did not work. I was just wondering if anyone else has this problem. When we are in a quiet anchorage, it is great, but the minute we get the slightest wave action, they start slapping. I suppose we could try sleeping in the aft bunk, but we have always used the v-bunk on all the boats we have owned since the mid-eighties…
Mike
Do you Yahoo!?Y! Messenger - Communicate in real time. Download now.
Posted by gjschouten (schouten@…>)
Hi Brian,
Confirm, large cable wrapes do work very well.
I love the simplicity of this perfect solution.
Good alternative to the aircraft surplus cable is the perhaps more
accessable “Oxygen free” loudspeaker cable that audio fanatics use.
This cable does not corrode like standard untinned cable and also has
a large conductor diameter which means that you actually end up with
close to 12 volt at the top of your mast. (Audio freeks look for low
ohmic behaviour)
It is available is every high end audio store, at a price of course.
Gio
— In freedomyachts2003@yahoogroups.com, “Brian Guptil”
<sailordude@b…> wrote:
Wire Slap!
will slip.
wiring should be.
that cable.
206-818-3203 sailordude@b…
Mike
Do you Yahoo!?
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Thanks Brian for the Brian Guptil <sailordude@…> wrote:
Wire Slap!
Mike
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
Hi Mike,
What size were the foam pieces that you used? Are you suggesting random sizes and shapes? How did you fasten them to the string? How did you fasten the string in the top of the mast? Does the halyard action tend to flake pieces of foam that collect in the bottom of the mast over time?
Mikemike_c_f35ck <mike_c_f35ck@…> wrote:
The simplest but least elegant cure is to hoist a series of lumps of foam tied to a thin line into your mast. Use one of the halyards to get this line through the mast. If you’re at it: pull up another line as a leader in case you want to pull up extra wiring.good luck.— In freedomyachts2003@yahoogroups.com, Mike Kovacic <sailslakemichigan@y…> wrote:> Greetings Fellow Freedom Owners!> > I have a 36 with a platform extension (Refuge, White Lake on Lake Michigan). I love the boat and have sailed from Cedar Point in Lake Erie to Muskegon in Lake Michigan with visits to many points in between including the North Channel. The boat has preformed well in all types of conditions. We do have one annoyance however, and that is the slapping of the wires that run to the
anchor light, wind instrument and anntenna through the inside of the mast. I tried using a series of foam wedges fastened on a 2X2 that I pushed up maybe 12 feet or so into the mast when it was down for winter storage. My thinking was that if the wires were tight inside the mast that is in the cabin this would reduce the noise in the forward bunk. But alas, this did not work. I was just wondering if anyone else has this problem. When we are in a quiet anchorage, it is great, but the minute we get the slightest wave action, they start slapping. I suppose we could try sleeping in the aft bunk, but we have> always used the v-bunk on all the boats we have owned since the mid-eighties…> > Your thoughts would be appreciated.> > Thanks > > Mike> > >
---------------------------------> Do you Yahoo!?> Y! Messenger - Communicate in real time. Download now.
Do you Yahoo!?vote.yahoo.com - Register online to vote today!
Posted by jaf177b6 (jfarrell@…>)
I had the same problem on my 1987 F36/F38 (hull 59) until I had the
mast rewired last winter (new anchor and steaming light and new VHF
cable). The entire mess was cable tied with foam insulation. I no
longer hear anything at all and I anchor frequently in Maine and the
boat rolls around a lot at its slip in Georgetown, ME. NOTE: I made
one mistake that I regret - that is I did not have the green bonding
(mast head ground wire replaced). It is pre-tinned wire vintage and
is not ABYC compliant for grounding, etc. If you are going to have
someone bundle your wires, you might consider replacing what needs to
be replaced and upgrading your ground while you’re at it. You would
be surprised at the corrosion over time (maybe less for you in a
fresh water environment). - Jim F.
My foam pieces were cheap sponges to wash your car with. At the top
of the mast, I used a few halp-sponges. I tied the sponges with
knots to the string with some 6-8 feet in between the foam blocks. I
have no internal halyards, so that’s no issue with me. I suppose the
foam wil flake over time, but only the bottom foam block wil drop
flakes inside the mast at the bottom.
Hi Mike,
mast over time?
Mike
of
to
good luck.
Lake
in
that
forward
have
mid-eighties…
Mike
Do you Yahoo!?
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
Service.
Do you Yahoo!?
Thanks for the reply…
Mike
jaf177b6 <jfarrell@…> wrote:
I had the same problem on my 1987 F36/F38 (hull 59) until I had the mast rewired last winter (new anchor and steaming light and new VHF cable). The entire mess was cable tied with foam insulation. I no longer hear anything at all and I anchor frequently in Maine and the boat rolls around a lot at its slip in Georgetown, ME. NOTE: I made one mistake that I regret - that is I did not have the green bonding (mast head ground wire replaced). It is pre-tinned wire vintage and is not ABYC compliant for grounding, etc. If you are going to have someone bundle your wires, you might consider replacing what needs to be replaced and upgrading your ground while you’re at it. You would be surprised at the corrosion over time (maybe less for you in a fresh water environment). - Jim F.
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
