Posted by methomp (methomp@…>)
Motored for 15 hours, no problems. Started the motor several times in
the slip after that. Took the family out and it acted like it ran out
of gas. Any ideas? I think maybe a filter, but I am not really sure
how to clean it or maybe how to bleed the air out of the lines. I have
the owners manual, but not a service manual. Help…
Sounds like dirt in the tank, clogging up the big “primary” external filter.
It will be some kind of spin-on unit. I had a Racor on Jabberwocky, although
it looked to have come with a Fram that wasn’t really appropriate. If you
have an F-28, it should be easy to open the inspection port and mop out any
debris, especially since it seems like you may be low on fuel. I used the
vacuum tank for draining the oil sump to empty the fuel tank and get down to
the stuff floating at the bottom. (yes, I’ve been here with this problem.)
The F-30 may be harder to get at. You can just change the filter, but if you
don’t cure the source, you’ll find yourself engineless again when you least
want it to happen.
dge
Sent: Sunday, June 05, 2005 10:00 PM
Subject: [freedomyachts2003] Yanmar 18hp problems
Yahoo! Groups Links
I had similar issues last year with my perkins. Here are some things
to check:
- check the racor filter.
- there should be an on-engine fuel filter too. If you’re lucky, it’s
a spin-on type and is easy to change. if you’re unlucky, you own a
Perkins.
- check the return line to the tank for blockages. This ended up
being the cause of my stalling - a blockage that got past the second
fuel filter and was causing pressure to build up and break the bleed
on the engine.
As far as bleeding the engine, the easiest thing to do is to find your
manual lift pump, then crack the tops of the cylinders one at a time,
starting closest to the pump. open about a quarter turn and pump until
pure fuel comes out the top, then tighten back down and move to the
next. Then crank the engine. 9/10 times it’ll start right up.
Lance
— In freedomyachts2003@yahoogroups.com, “methomp” <methomp@c…>
have
Just a suggestion. I had severe problems when I first got my F33,as someone
had put a 2 micron filter on the primary(Racor). It should be a 30 micron
filter,and the secondary,on the engine is ,as I’m told,4 microns… The 2
micron clogged up in a few hours. It is not meant to be a primary.
Sent: Sunday, June 05, 2005 10:13 PM
Subject: Re: [freedomyachts2003] Yanmar 18hp problems
filter.
although
any
to
you
least
want it to happen.
dge
Yahoo! Groups Links
Yahoo! Groups Links
Posted by Jay T. Reed (reedjayt@…>)
Last year when I purchased my 35 Freedom, I also purchased a Yanmar repair
manual from Seloc Publications. It’s available from Amazon for $26.53.
I’ve found this very helpful as I’ve changed both fuel filters, and the
water pump impeller.
Reply-To: freedomyachts2003@yahoogroups.com
Date: Mon, 06 Jun 2005 16:29:56 -0400
filter.
although
you
any
down
to
problem.)
you
least
want it to happen.
dge
Yahoo! Groups Links
Yahoo! Groups Links
If you do not own a Yanmar 2GM20F service manual you
are missing one of the best investments you can make.
Get the parts manual also. Together they run about
$70.00. Extremely useful information that will save
you $70.00 the first time you can troubleshoot/fix a
problem yourself.
are some things
to check:
you’re lucky, it’s
unlucky, you own a
Perkins.
This ended up
past the second
break the bleed
on the engine.
do is to find your
turn and pump until
and move to the
right up.
Lance
<methomp@c…>
am not really sure
of the lines. I
have
Help…
Do You Yahoo!?
http://mail.yahoo.com
I agree,but some info is not given. For instance,on the FW cooled Gm,the
alternator and raw water pump belt sizes are not given,only Yanmars part #.
The sizes are A 37 for the alt,and 3L 190 for the salt water pump belts. You
do need the books for service and maintenance,such as torqueing the head
bolts and valve adjustment.
Sent: Monday, June 06, 2005 11:17 PM
Subject: Re: [freedomyachts2003] Re: Yanmar 18hp problems
problem yourself.
are some things
to check:
you’re lucky, it’s
unlucky, you own a
Perkins.
This ended up
past the second
break the bleed
on the engine.
do is to find your
turn and pump until
and move to the
right up.
Lance
<methomp@c…>
am not really sure
of the lines. I
have
Help…
Do You Yahoo!?
Yahoo! Groups Links
