My F-36 also has a small leak, apparently from the rear seal of the transmission or, since the oil is black from the crank. Not much oil leaks but it does miss the drip pan under the engine and therefore ends up in the bilge if I am not quick enough changing the diapers (depends work well). I use 10-40 oil in both engine and transmission.
Any suggestions?
Bill
_________________________________________________William A. Cormack, CPAPrincipal and Chief Financial OfficerWhelan Associates, LLC, a Corporate Real Estate Service firm100 Faunce Corner Executive Center500 Faunce Corner Road, Suite 150North Dartmouth, MA 02747Voice: 508-984-4100, Fax: 508-984-4101, Cell 508-254-5828MailTo:wacormack@…
