Freedom 40/40 PHRF
TonyB
Freedom 40/40 PHRF
Post by TonyB »
Hey folks,
I recently received my NorCal PHRF certification. I got "murdered" with a rating of 81. I plan on appealing this rating. It seems very low. This is with the self tacking (roller furling) headsail, and spinnaker. The base rating was 90 and they dinged me for a 10% over length pole (even though it is stock and dimension are in my manual). And for a 20% over sized spinnaker. I am pretty sure the oversized pole and spinnaker are by design given the very short J measurement due to the forward placed mast.
Since I am the first 40/40 in Norther California to get a rating the committee is essentially starting from scratch.
In my internet explorations of ratings for the 40/40 the lowest I found were several 99s.
So I am wondering if any of you have been through this process. What your base rating was and what headsails and spinnakers you used. Also if anyone has any documentation for a "stock" spinnaker for the 40/40.
Thanks!
Tony
Tony
SV Circe 1997 Freedom 40/40 - Hull #20 - Brickyard Cove Marina, Richmond, CA
Camino
Re: Freedom 40/40 PHRF
Post by Camino »
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
TonyB
Post by TonyB »
Yes thanks Camino. That is where I started. Then did a lot more digging. Like I said 99 seems
The lowest base rating for a deep keel 40/40. But here is no indication if those boats were tall or short mast, carrying spinnnkers, length of spinnaker pole etc. What headsails they were carrying etc.
Tony
