F21 First sail
newt2u
F21 First sail
Post by newt2u »
We have a Freedom 21 with twin drop keels. It's been in our drive being refurbished since we purchased it in October, as previously it had been sat on a boat yard for 18 years. I was planning to launch it at Milford Haven in April but Welsh travel restrictions were not lifted until late July. But after a long wait, it's now in the water and we have had it out for a couple of trips up and down the waterway. The first in 8-10knts, photos attached, was in gentle introduction to how she handled. The second time was a bit more fun, as we had 14 kits gusting 18 at times with a full main and small jib. I was surprised at how well behaved she was as I was expecting her to be a lot more tender. Have not flown the spinnaker yet, as the first time out we had some rigging issues and the second time a wind swing over lunch time at Dale meant we were on the wind both up and back.
drcscruggs
Re: F21 First sail
Post by drcscruggs »
Smart looking red dodger. I like it.
newt2u
Re: F21 First sail
Post by newt2u »
Yes, the old one was a bit moth-eaten, I got my local sailmaker to make one up from the taters of the old one. The only downside is the main sheet. I have to bring it down through a fixed block on the cabin roof, which means I have to adjust the sheet between tacks, unless I keep the traveller dead centre.
Castaway
Re: F21 First sail
Post by Castaway »
Wow! That really looks good. Would you care to nip up North and re-furbish mine, too?
We have no sprayhood, but only used it for brief day sails in Spain, so that was no problem. The cockpit cover, which disintegrated, is a miss, though.
Enjoy your sailing.
Gerald
Gerald Freshwater,
Lerwick Boating Club
Shetland Isles, Scotland
newt2u
Re: F21 First sail
Post by newt2u »
Not my first sail, but put together of a video of a recent outing in Milford Haven. Fabulous sunny September day with around 15knts of wind but quite variable. We had a long beat up against wind and tide followed by a much swifter run back down to the Marina. Recorded 6.5knts on a reach but unfortunately both iphone and fixed sports cam battery gave up before we raised the Spinnaker. Suspect we were doing more on the run. Anyway here is a link to the video if anyone is interested.
Click here
From Clipboard.jpg (165.33 KiB) Viewed 980 times
drcscruggs
Re: F21 First sail
Looks like a good day. Thanks
chadrider
Re: F21 First sail
Post by chadrider »
Looks like fun! I really like the dodger! I don't know how you rigged the mainsheet, but I am thinking of bringing the tail forward to the mast and then back to the cockpit. When singlehanding, it is hard to adjust when under a lot of load or with the traveler eased down or, in your case, with the dodger up. I love how sneaky-fast the F21 is off the wind! Not a sportboat on the edge, just quietly going faster than you might expect for a 21.
Chad Rider
Rumford, RI
02916
Freedom 21 "Frisson"
1984, Deep Keel, Gunmount.
newt2u
Re: F21 First sail
Post by newt2u »
Hi chadrider,
yes with the dodger there is a problem with the main sheet. My first solution was to take the main sheet forward and turned back on the starboard side about mid saloon roof. This was OK but port and starboard tack required easing and tightening the sheet, not ideal. This sail I moved the block up to the kicker fixing on the boom, then back to the starboard side. This was much better but not ideal, only a slight adjustment needed but ignored on my frequent tacks, however it catches on the cutout in the doger. I could not do it with the current sheet length but my final solution will be main sheet forward from lower fiddle block up to lazy jack mount forward, then down to the mid saloon deck and back through the dodger cutout to a jammer on the deck. It does not need to go right to the mast and I am averse to drilling more holes win the mast. The boom pad eye for the Ladyjacks is plenty strong enough and far enough forward to have negligible difference on sheet length when tacking.
newt2u
Re: F21 First sail
Post by newt2u »
Here is a clip from the video that shows the intermediate solution.
Main sheet.jpg (169.28 KiB) Viewed 1596 times
