Every project will have scope creep. After successfully replacing 8 ports in Glory with Newfound Metals ports, it was time to do the last 4 up forward.
After removing them, it was clear that the horizontal slats needed to come out too, since many had bowed, the screws were corroded, and there was no way new ports were going to seal properly.
What I didn't know is that those horizontal slats are stapled to a thin sheet of luan. So after disassembling all of the furniture in the v-berth, I was able to get the slats out and back to bare fiberglass, which looks to be in pretty good shape.
Of course now I have to figure out what to put back in there and how to make the templates. we are leaning toward formica because it's durable, can be rolled, and is easy to clean. Has anyone else done this particular job? If so what materials did you use, and how did you template it? I'm thinking of doing it the same as a countertop but I've never really worked with formica before.
Before:
After:
Cabin Walls
Cabin Walls
S/V Glory, 1992 Freedom 45 CC TM WK
Re: Cabin Walls
I am doing them on my M 28 using red oak w/Waterlox polyurethane. I made the template w/ luan strips and hot glue. I also scrubbed all the teak bulkheads and teak trim w/ 2 part Snappy teak. luckily the interior was oiled not varnished, so I didn't need to strip it. It cleaned up nicely, and now will get a light sanding and 3 coats of poly.
John Eaton
John Eaton
Re: Cabin Walls
Hi Lance, When I stripped out the V-berth of my trawler I put up strips of mahogany finished with polyurethane. I was pleased with the results.
- IMG_0109.JPG (1.9 MiB) Viewed 3789 times
