HEAVE TO
Zengirl2
HEAVE TO
Post by Zengirl2 »
Have you done this in a Freedom 32. Can you explain steps needed to practice this maneuver?
VeloFellow
Re: HEAVE TO
Post by VeloFellow »
If you put F32 Gale into search, you will see Dale Tournier's description of what he did with his F32 heaving to.
Mike
s/v Clave'
1981Freedom 28 #112
Currently sailing Tampa Bay
yanmar 2ym15 2blade prop
Zengirl2
Re: HEAVE TO
Post by Zengirl2 »
VeloFellow wrote:If you put F32 Gale into search, you will see Dale Tournier's description of what he did with his F32 heaving to.
Thanks, will check it out.
JohnReinagel
Re: HEAVE TO
Post by JohnReinagel »
I have had success testing this on my Hoyt 32. I simply tied the camberspar clew end to the toe rail with some spare line when on a given tac, then came about to back wind it. The boat settled in quite well after a bit of trial and error. It would not be very difficult to rig some blocks and line to make this doable from the cock pit.
John
1984 Hoyt F32
Hull #53
