Electric head replacement
bobr
Re: Electric head replacement
Post by bobr »
Greywine wrote:
Sat Apr 03, 2021 1:57 pm
Even knowing this is possible, I don't see how to get the old head removed. Any tips?
Do you have an inspection port in the base that the throne sits on? By opening up the port I was able to get a ratchet in there on the nut and get the bolts off. It wasn’t easy or a lot of fun but doable :mrgreen: if you don’t have a such port you could cut one in yourself using a large hole saw. It may not seem like it now, but it’s a worthwhile upgrade!
Bob R.
1995 Freedom 35 (Pedrick)
"Liberty"
Old Saybrook, CT
Castaway
Post by Castaway »
I've already replied on the next thread, which you started, but looking at your picture here, and checking back through my notes, I think the the original base for the heads unit was only screwed in place, and, after unpicking all the silicone bathroom sealant, I could actually lift it out. (Of course, by then, I had already had at it with a jigsaw!). You could give that a try, after removing pipework and the bowl. For replacement, just reverse the coachbolts into the same holes. The square section will stop them from rotating, and a touch of silicone will stop them from falling out if not quite solidly in place.
Gerald Freshwater,
Lerwick Boating Club
Shetland Isles, Scotland
