Freedom 45 CC 2nd Manual Bilge Pump
LanceRyley
Post by LanceRyley »
I may have a requirement to have a 2nd manual bilge pump "permanently installed." the current setup is an automatic pump that discharges in the forward head. There is a manual whale pump in the cockpit. If I install a 2nd manual pump, it is supposed to be operable from below.
When I look at the layout of the boat down below, there's no obvious place to put another bilge pump. Are there any F45 owners who have done this, and if so, where did you put the pump and the hoses?
thanks,
S/V Glory, 1992 Freedom 45 CC TM WK
