toilet removed in a freedom 35 Pedrick
Posted: Sat Apr 03, 2021 2:42 pm
by Greywine
Hi all,
Anyone have any ideas on how to remove an old toilet from a Freedom 35? The screws or bolts attaching the old toilet to the pedestal don't have a head to turn. Am looking to put in an electric toilet but am stuck removing the old one first.
John, new owner of a 1996 F35 named Liberty (although we've been calling her Libby)
Re: toilet removed in a freedom 35 Pedrick
Posted: Sat Apr 03, 2021 6:06 pm
by GeoffSchultz
Those are carriage bolts that have a square piece under the cap that keeps them from turning when tightening. "All" that you have to do is to access the nut on the bottom and loosen it. Clearly, a trivial operation, for which I have no suggestions!
Posted: Sun Apr 04, 2021 10:52 am
by Greywine
Dang, I was hoping for a quick fix. Thanks anyway for the response.
Posted: Sun Apr 04, 2021 10:13 pm
by Camino
Greywine - as in my post on this topic, my f35 P has wood screws instead of carriage bolts with the nuts under. Geoff is correct - take measurements of your head base - mine (1999) has a 5” shelf on which the head sits. Choose an access hatch that’ll fit (can you get your hand in there once fitted with a socket wrench) - either a circular or rectangle access hatch. Cut the hole and unbolt the thing. My toilet base looked way different than yours Can you take a pic of your base?
Posted: Mon Apr 05, 2021 5:21 pm
by GeoffSchultz
After thinking about it, I have an inspection plate under my sink. In theory, I could get my arm through it and get a socket wrench with an extension on it to the toilet. I've never had to do it, and really don't want to try. It really makes you wonder how they assembled these things! Good luck!
Posted: Mon Apr 05, 2021 10:38 pm
by bobr
I posted this in the other thread on this topic, icymi.
Do you have an inspection port in the base that the throne sits on? By opening up the port I was able to get a ratchet in there on the nut and get the bolts off. It wasn’t easy or a lot of fun but doable
if you don’t have a such port you could cut one in yourself using a large hole saw. It may not seem like it now, but it’s a worthwhile upgrade!
Posted: Tue Apr 06, 2021 7:29 am
by Pearce
Hello,
Access port mentioned previously seems like the best solution. Would probably need a new access port to tighten new head bolts eventually. So might as well cut that and see if a socket would work on the old bolts. If bolts are seized up perhaps an oscillating saw, a dremel or a hole saw from the top would do the trick. If you cut the bolts the other end is likely to drop and roll around and make an annoying rattle when the boat moves. Could remove the cut ends with the access port too.
Good Luck,
Posted: Thu Apr 08, 2021 11:14 am
by Castaway
I did this job on my F35/33. Since I had decided to replace the board on which the toilet sat, I cut it open with a jigsaw to get at the bolts below. When replacing the base, I carefully placed the toilet on the new, unfitted, board, and marked the hole positions. Then I put coachbolts in from below, tightly fitted, and fastened the base in place (screws and glue; the loads can be substantial at sea). The toilet is now held in place with dome headed nuts, which can be undone as necessary without access to the underside. The baseboard is waterproof, and the dome nuts are easy to clean.
A couple of small holes near the lowest point of the enclosure allow for any unexpected leaks; two holes provide for the use of a syringe and thin tubing in case of anything distasteful!
[/img]
- partway through
- heads.jpg (30.86 KiB) Viewed 5225 times
[img]
- nearly finished
- heads 2.jpg (29.07 KiB) Viewed 5225 times
