F35 holding tank
Greywine
F35 holding tank
Post by Greywine »
Hi all,
So I installed a new electric toilet which works beautifully (after mich gnashing of teeth) in my Freedom 35 (Pedrick). Unfortunately, there's a massive hole in the bottom of the holding tank where it corroded away after being exposed to urine and poop for 25 years. Soy head is useless because it just pumps into a tank and then flows into the bilge. At least I discovered this during the testing phase.
Anybody know how to reach Freedom for parts, ie a holding tank? I heard they're still around. Any experience getting parts for their boats? Any chance they're making plastic versions of their old tanks?
John
Camino
Re: F35 holding tank
Post by Camino »
Greywine
Recommend contacting Paul Dennis Warren River Boatworks WRBtwks@aol.com. I believe you’ll need to carefully cut a large access panel from your aft cabin, remove the old tank and find another plastic tank of suitable size and shape.
Good luck.
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
Greywine
Post by Greywine »
Hi Camino,
Thanks for the reply and the recommendation. As you said, we had to get access through the aft cabin, starboard wall. Just when it was starting to look like a tiny home, now it once again looks like a construction zone. Oh the joys of boat ownership!
Camino
Post by Camino »
Right - love it :D I have crouched on top of my holding tank from access from the starboard lazarett- thought I’d never be able to clamber out. You’ll do it! Dealing with a bent prop shaft and an 80 nm motor back to the boat yard - very slow. So know what you mean.
Tom and Stephanie
1999. Wing Keel 5’
Emery Cove, CA
Salacia
Post by Salacia »
I’ve never done it but I have analyzed how to. In the back of the deck (rope) locker on starboard is a board that is removable. That gives you access to fittings on the top of the tank. Then the fun starts. Remove the panel from the foot of the bunk ini the aft cabin. Getting to the panel means rolling up the mattress and removing it.
There are bound to be identifiable mounts to loosen the tank.
Ideal time to change all your hoses. What fun!!!
A good yard should be able to fabricate a new tank. At home I have a drawing of the tank. I think it was made by RBS.
Keep us posted on how it goes.
Stephen Lee
Salacia
F35 Pedrick
Marblehead MA and Rockland ME
Salacia
Post by Salacia »
I found a drawing of the tank! RDS manufacturing. Found them online. But check around locally too. Best of luck.
holding tank copy.pdf
(61.13 KiB) Downloaded 246 times
Stephen Lee
Salacia
F35 Pedrick
Greywine
Post by Greywine »
Hi all,
I ended up going with Ronco's RV2W:
https://www.ntotank.com/32gallon-ronco- ... k-x6794741
It was pretty cheap, as far as these things go, and directly from Ronco it took 10 days to arrive. We also got the standing pipe fitting. Now all the hose connections are on top of the tank which makes it much easier to service from the cockpit locker.
My design included building a plywood/epoxy/fiberglass platform that the tank sits in (12" wide, 37.5" long with 12" walls). If you take out the aft cabin wall you can lift the suitcase sized 12x19x37.5 inch tank and platform up until it's parallel with the aft locker wall. I then built some custom 2x4 legs (upside down Ls holding up the platform and then going down parallel to the aft cabin wall along with a diagonal making it a triangle). These were treated lumber, deck screws and construction adhesive. The next day I tabbed everything to the hull.
At the end of the day, we lost about 8gallons of blackwater volume, but gained a solid polyethylene tank that should outlive the boat. As the bonus, with it's height partially above the aft cockpit wall, we'll be able to tell when it needs a pumpout.
John and Ruth
1996 Freedom 35 Liberty
Rock Hall, MD
