And it begins
Re: And it begins
Leak found.
- 20210324_150340_compress2.jpg (108.89 KiB) Viewed 2524 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
New fittings today. I have 3 weeks to get the motor running and back to the slip. Summer rates on the hard kick in and triples the price.
- 20210414_110450_compress94.jpg (65.3 KiB) Viewed 2454 times
- 20210414_110542_compress61.jpg (94.19 KiB) Viewed 2454 times
- 20210414_104738_compress15.jpg (58.12 KiB) Viewed 2454 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
And back to it.
Well after 5 surgeries in the past 11 months I am finally getting my strength back to start back up again.
Pulling the boat this Saturday to place on the hard for the winter. I have a slow "Seep" that I need to fix. Afterwards I will start up projects as winter allows in regards to drilling holes topside. I think insulating the cabin top will be my next progression minus the locations I need access.
Currently working on replacing both sails and the running rigging. I have another post in that section.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Yea made it to Anchorage driving thru a winter storm. Now off to the Evil Store (West Marine).
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Well back to it. Today was a multitude of things.
1. Cover the cockpit and secure the A-frame for high winds.
2. RV antifreeze the motor. If curious I poured the antifreeze down the raw water hose and turned the motor by hand until I had it coming out the exhaust elbow. I had the exhaust hose removed for the following.
3. Start to look into a chronic leak (seep) at the lower gudgeon. If the bilge pump stopped it fills the bilge to the floor boards in 5 days. This was how I found the leak to begin with. Photos to follow.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Cockpit cover. We average 30-50 feet (900-1500 cm) of snow each winter.
- 20210925_162856_compress66.jpg (68.99 KiB) Viewed 2003 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Da leak location. Not quite sure "where" from the outside. It seems like it is seeping from the bottom.
- 20210926_135213_compress50.jpg (107.72 KiB) Viewed 2003 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
External views.
- 20210926_141227_compress30.jpg (81.99 KiB) Viewed 2003 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Another view
- 20210926_141235_compress13.jpg (79.62 KiB) Viewed 2003 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
And the other side. I didn't see any obvious cracks. Could be behind the wedge between the gudgeon and boat. I am suspect of the bolts...
- 20210926_141600_compress53.jpg (113.05 KiB) Viewed 2003 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
