Here's a maintenance/ repair item I don't recall having been discussed before:
How do I get rid of the wasps that have built a nest inside the boat between the cabin top and the headliner, right above the stove? There is a small opening in the edge of the headliner they are going in and out of. There's not much access for me, but I guess I'll try spraying some hornet spray in there then running like hell.
I also wonder how they are getting in and out of the seemingly closed-up boat. The Nicro vents in the overhead hatches is all I can think of.
Has anyone fought a wasp problem before?
Wasps!?
- Rick Simonds
Wasps!?
___________________________
Rick
Tallahassee
Rick
Tallahassee
- Rick Simonds
Re: Wasps!?
That's a good idea. I do see the occasional other bug (this is Florida. Florida is wildly bug-friendly.) Maybe bombing the whole boat would fix it all.
It also occurred to me today to just walk around pushing up hard on the headliner to squash the nest and its occupants.
Rick
Tallahassee
Rick
Tallahassee
- moosemcclintock
Re: Wasps!?
I had a nest of carpenter bees in my house, I hit the nest with wasp spray and they came out through every fitting in the ceiling and crevice in the wall, they have the ability to get through incredible small holes, I'd think wasps are the same. If you spray you have to run, the good thing is that they never nest in the exact same place again so you'll probably be rid of them.
Re: Wasps!?
Another solution is to just vacuum the wasps up as they come out of their hole. Takes a while, but eventually they will all be gone and the colony will die. I did this with some yellow jackets that had nested in the roof of my house. Of course- I had to run the vacuum all day to do it, but it works. (I just positioned the vacuum hose next to their hole and ran it- they would fly toward the hole and get sucked right up. The trip into the vacuum kills them.)
- hxschiller
- Location: Mull 28 - "Impulse" on NW Creek in New Bern, NC
Re: Wasps!?
To make sure you kill the insects, put a few moth balls in the vacuum cleaner bag.
- Rick Simonds
Re: Wasps!?
No wasps could be seen or heard aboard Justiina this weekend, and I stayed aboard 2 nights, armed with all sorts of weaponry. I sprayed some wasp spray into where I had seen them and no reaction one way or the other. I did see a trail in the rain gutters of the main companionway sliding hatch so I think that's where they are getting in. Sprayed a little there, too.
It's still a mystery, or maybe the problem just cured itself...
Rick
Tallahassee
Rick
Tallahassee
