Will start the glass layup in a few days.
And it begins
Re: And it begins
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
Back to getting the tombstone "bow sprit " ready. Laying up fiberglass mat for now. Fairing compound to follow.
- 20230525_115907.jpg (2.43 MiB) Viewed 1595 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Progress
- 20230526_141556.jpg (2.04 MiB) Viewed 1571 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
1st coat of bottom paint.
- Compress_20230528_174423_3403.jpg (943.98 KiB) Viewed 1556 times
- Compress_20230528_174422_2491.jpg (868.3 KiB) Viewed 1556 times
- Compress_20230528_174421_1566.jpg (845.76 KiB) Viewed 1556 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
1st coat epoxy paint for bow sprit.
- Compress_20230528_174420_0590.jpg (916.47 KiB) Viewed 1556 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Re: And it begins
Dry fit. Some modifications needed.
Looks like I also need a new phone.
- Compress_20230606_192147_7241.jpg (59.9 KiB) Viewed 1498 times
- Compress_20230606_192146_6979.jpg (39.9 KiB) Viewed 1498 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Have the lower gudgeon in Anchorage. New brass bearing and clean up of the actual gudgeon being done. Nothing easy or cheap in Alaska. 12 hour drive and $1200 bill staring me in the face.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
New shaft seal.
- Compress_20230609_104545_5249.jpg (408.58 KiB) Viewed 1449 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Hmm guess I should paint back there before putting the motor in...
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
