And it begins
Re: And it begins
Today at lunch was prep for new transducer. Will work on the final installment Wednesday. Need to epoxy the hole tomorrow morning.
- Compress_20220626_194747_7704.jpg (332.55 KiB) Viewed 2469 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
Shiney red thing showed up today.
- Compress_20220630_214739_9028.jpg (354.99 KiB) Viewed 2433 times
- Compress_20220630_214736_6637.jpg (380.48 KiB) Viewed 2433 times
- Compress_20220630_214734_4060.jpg (364.25 KiB) Viewed 2433 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
More photos
- Compress_20220630_214737_7530.jpg (369.03 KiB) Viewed 2433 times
- Compress_20220630_214733_3169.jpg (381.74 KiB) Viewed 2433 times
- Compress_20220630_214732_2008.jpg (358.29 KiB) Viewed 2433 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
And yes I see other shiny red things in the background... (1 more year and permanent vacation)
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Sweet engine! Beta is the repower brand of choice around here, lots of happy customers!
Bob R.
1995 Freedom 35 (Pedrick)
"Liberty"
Old Saybrook, CT
"Liberty"
Old Saybrook, CT
Re: And it begins
Astounding success! I really like the access to the impeller / water pump ! Edit - and…. Your alternator looks powerful!
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
1999. Wing Keel 5’
Emery Cove, CA
Re: And it begins
70 amp. Should be fine.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Additional goodies.
- Overall view
- Compress_20220701_205604_4013.jpg (339.46 KiB) Viewed 2383 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Panel
- Panel cable and spare parts
- Compress_20220701_205602_2062.jpg (333.46 KiB) Viewed 2383 times
- Prop
- Compress_20220701_205603_3099.jpg (339.44 KiB) Viewed 2383 times
- Panel
- Compress_20220701_205600_0594.jpg (341.48 KiB) Viewed 2383 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Mock up of the lower half of the motor. Will have to create new aft brackets. Still need to fix:
Leaky lower Pintle rudder bolts.
Pull prop and replace but....
Also need to pull shift and inspect the stern tube. May have a bigger repair than expected.
Oh yeah and a new water intake setup.
Then maybe bring the motor down to the boat. I do get a little time off in September.
- Compress_20220806_185913_3170.jpg (295.68 KiB) Viewed 2133 times
- Compress_20220806_185912_2883.jpg (231.98 KiB) Viewed 2133 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
