And it begins
Re: And it begins
Flywheel is pretty rusted. May be hard to see.
- 20211219_114255_compress92.jpg (126.08 KiB) Viewed 2210 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
So last one for today. I measured all the angles of the engine beds in relation to the floor. Right now I am sitting a little nose high on the hard. I am going to draw up a diagram and will post it here if anyone likes.
I do need to touch bases with Beta before pulling the engine. I am going to do it in sections once I start. I am also going to see if the high school wants it for a project in their automotive class. If not then I will see if anyone here would like bits & pieces.
I also have a brand new raw water pump in a bag. Was from my last boat (3gm30).
- 20211219_125841_compress47.jpg (110.84 KiB) Viewed 2201 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Oh and I forgot - Merry Christmas...
- FB_IMG_1639712630516_compress79.jpg (54.94 KiB) Viewed 2193 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
That engine install is going to be such an improvement! I had a much easier time measuring after my old engine was gone. I did support the prop shaft because mine dropped a bit when not coupled to the transmission. Everything was measured off of the prop shaft end height and angle. I used the standard feet and used some epoxy coated white oak blocks to go up and get the angle right. I wish I was 1/4" forward of where it ended up
Re: And it begins
I am giving Beta a call tomorrow to touch bases and ask a few questions. My aft engine beds angle is 10-degrees slopping aft. Prop shaft is the same. Current yanmar is basically the same depending on where I measure. Does the beta sit flat?
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Pulling engine apart. Have the head removed. Hmmmm I see A Leaking HEAD GASKET and antifreeze in the cylinders...
The pile of goodies is growing.
- 20211222_121955_compress63.jpg (110.75 KiB) Viewed 2092 times
- 20211222_122009_compress20.jpg (72.77 KiB) Viewed 2092 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Shaft is free. Was very tight on the starboard side.
- Tight stern tube
- 20211222_134513_compress55.jpg (81.41 KiB) Viewed 2084 times
- Removal tools
- 20211222_133123_compress92.jpg (78.76 KiB) Viewed 2084 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
And a good place to stop. Engine is free - just need a hoist and a helper. AKA my 21 year old son.
- 20211222_140542_compress16.jpg (95.55 KiB) Viewed 2084 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
So maybe a little redneck - but I'm from Florida and Louisiana.
- 20211223_130853_compress88.jpg (43.85 KiB) Viewed 2045 times
- 20211223_113044_compress49.jpg (96.28 KiB) Viewed 2045 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Up and off space. Now to get it out the companion way. Next phase.
- 20211223_132827_compress0.jpg (67.26 KiB) Viewed 2045 times
- 20211223_133800_compress8.jpg (68.26 KiB) Viewed 2045 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
