And it begins
Re: And it begins
So back to the original game plan. Bevel each hole, where possible, 12:1 and lay up multiple layers of glass with some 404. Will 410 afterwards. Still considering the sleeve method.
Oh and I will remove that "Back Plate Spacer" to inspect the screw holes and fill with epoxy.
The biggest issue will be low crawling into the back to set up a backer so the epoxy will not free-flow. AND the weather. Suppose to snow/rain for a week.
- 20211005_123054_compress50.jpg (92.42 KiB) Viewed 2439 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
Hmmm... here's an idea... What size is your bolting? There is braided fiberglass tubing that you could sleeve the holes with. That would have the best chance of bonding to the hull and creating a seal. Go slightly oversized on the id, wax your bolts, fill the holes with thickened epoxy, and support the rudder during assembly to get everything aligned properly.
Sounds easy
Sounds easy
Re: And it begins
Hmm - Thinking either the 1-1/4 or 1-1/2...
Structural FRP Fiberglass Round Tubes
Color: Green
Temperature Range: -60° F to 140° F
Tensile Strength: 7,000-30,000 psi (Good)
Impact Strength: 4-25 ft.-lbs./in. (Excellent)
Hardness: Barcol 45 (Hard)
For Use Outdoors: Yes
Strong and lightweight, these FRP fiberglass tubes are an alternative to wood in structural applications. They are made of fiberglass-reinforced polyester.
3D CAD models availableFor technical drawings and 3-D models, click on a part number.
5 ft. Lg.
10 ft. Lg.
OD OD Tolerance ID Straightness
Tolerance Each Each
1/8" Wall Thick. (-0.0400" to 0.0400")
1" -0.04" to 0.04" 3/4" 0.03” per ft. 8535K71 $25.09 8535K21 $43.51
1 1/4" -0.04" to 0.04" 1" 0.03” per ft. 8535K26 30.92 8535K76 53.78
1 1/2" -0.04" to 0.04" 1 1/4" 0.03” per ft. 8535K72 35.27 8535K22 61.32
1 3/4" -0.04" to 0.04" 1 1/2" 0.03” per ft. 8535K27 38.59 8535K77 67.11
1/4" Wall Thick. (-0.0400" to 0.0400")
2" -0.04" to 0.04" 1 1/2" 0.03” per ft. 8535K73 71.90 8535K23 128.97
1/2" Wall Thick. (-0.0750" to 0.0750")
3" -0.04" to 0.04" 2" 0.03” per ft. 8535K74 160.90 8535K24 289.75
Color: Green
5 ft. Lg.
10 ft. Lg.
Tolerance Each Each
- McMaster Fiberglass Tube.png (4.99 KiB) Viewed 2421 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Something like this? McMaster-Carr Page:
https://www.mcmaster.com/Hollow-Rods/ha ... ss-fabric/
Re: And it begins
Ships passing in the night...
Re: And it begins
So Typical Up Here.....
McMaster
39" section was $79.
Shipping to Alaska $92.
Nope I shall keep looking
McMaster
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
McMaster is great if you need it tomorrow and don't have time to search for another source, But they are very expensive.
I am searching for fiberglass tubing for a different project and found this source: https://mgs4u.com/product/1-od-round-tube/
They offer similar pultruded fiberglass tubing, 1" OD x 3/4" ID in pre-cut lengths of 6", 23-1/4", 48-1/2", and 93". Shipping on the 6" or 23-1/4" pieces should be more reasonable, even to Alaska. The 23-1/4" piece is $6.30 and for reference, they offer shipping to Anchorage is $17.95.
Cheers
Cheers
Dwight Escalera
Accredited Marine Surveyor, SAMS #1024
former engineer at Freedom Yachts
former owner F36-71
Wakefield, RI
former owner F36-71
Wakefield, RI
Re: And it begins
Yes so much better with S/H. I need to head down and measure. The 6" version may be the ticket. Now for the weather to warm up to above freezing. Thanks for the research. It's one less thing to do.
NOW to purchase 1000-ft of Line to replace ALL of the running rigging. $190 to ship 4 (300-ft) spools to Alaska. Not too bad.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Today I THREW some 404 slop over the holes as a temporary solution to keep rain out. Will not get to the actual fix till spring.
I also had a coworker fly his drone to get some mast head views. Looks like my main had a "rub spot" that will need attention also this spring.
- Photo_1080295495_DJI_71_jpg_4402967_0_2021109131418_photo_original_compress57.jpg (74.58 KiB) Viewed 2334 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
View of a similar design sail for my mizzen and main. Slides will not present, instead grommets every 2-ft to lacing
- redtuxpackage.jpg (130.39 KiB) Viewed 2287 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
