And it begins
Re: And it begins
Motor up, motor out, started to wipe things down but too cold. Windex and degreaser freezing to hull. 9-degrees F outside.
- 20211223_153846_compress98.jpg (68.8 KiB) Viewed 2373 times
- 20211223_142024_compress35.jpg (94.27 KiB) Viewed 2373 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: And it begins
And its out. At home working on removing the tyranny and aft brackets.
- 20211224_105446_compress40.jpg (124.82 KiB) Viewed 2359 times
- 20211224_110057_compress84.jpg (118.78 KiB) Viewed 2359 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
So after various mockups (Flat footprint of 30 - vs - 25) and a 3-d model with the sump and feet attached I have stepped down to a 25. The 30 was, for lack of better terms, going to be a bitch to install due to width mostly. I did not want to push the 30 out into the cabin and extend (replace) the shaft and rebuilt the engine compartment around all of that. SO Beta 25 it is. I go from 7.4 to 7.1 regarding speed....
I have been putting info in the below talk.
viewtopic.php?f=8&t=13385
Now with that said the new sails are almost done and should be shipped here in a week or so.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
New sails have arrived. It will be a few months till mother winter is gone before I can "raise them". Beta 25 is approximately 3 months out so I may have a functional boat this summer. Gives me time to do other projects - sort of. No Fiberglass work till it warms up.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Working on figuring out how-where the new motor will go. May have to cut out the original engine catch and make new mounting beds.
- Center line
- 20220301_153040_compress49.jpg (69.65 KiB) Viewed 2051 times
- 20220301_152325_compress45.jpg (84.19 KiB) Viewed 2051 times
- 20220301_153032_compress20.jpg (86.03 KiB) Viewed 2051 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Still no motor. Rented the lift and worked on the main and mizzen tops, new rigging and started to get the new sails configured
- Compress_20220515_140037_7085.jpg (270.44 KiB) Viewed 1827 times
- Compress_20220515_140035_5890.jpg (272.9 KiB) Viewed 1827 times
Last edited by Sailing-61-North on Sun May 15, 2022 7:04 pm, edited 1 time in total.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
More up top photos.
- Compress_20220515_140042_2463.jpg (230.79 KiB) Viewed 1826 times
- Compress_20220515_140038_8358.jpg (225.55 KiB) Viewed 1826 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
45-ft lift was just tall enough.
- Compress_20220515_140044_4198.jpg (278.22 KiB) Viewed 1826 times
- Compress_20220515_140041_1324.jpg (268.81 KiB) Viewed 1826 times
- Compress_20220515_140039_9838.jpg (285.65 KiB) Viewed 1826 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Re: And it begins
Really nice! New beta will be terrific.. I love your masthead- so functional! Antennas - is the one a cell booster?
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
1999. Wing Keel 5’
Emery Cove, CA
Re: And it begins
Not sure. Those were all the old stuff I took down. It actually started to crumble as I removed it.
My addition was a Davis Wind Vane on the mizzen. Both main and mizzen got new blocks and a check. All new lines (rigging) was mostly installed. What is left I can get at deck level.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
