F30 Bottom Paint Estimate
I need to get bottom paint and I was wondering if anyone had a good number of how much it might take to do the bottom of an F30.
Re: F30 Bottom Paint Estimate
I typically use about 1.5 gal on my F28.
Walter Gotham
Salem MA USA
Salem MA USA
1.5 Gallons. Might use the extra half for another coat especially on the waterline and rudder.
Defender has a nifty paint calculator that includes coverage by paint brands.
https://www.defender.com/html/bottom_paint_calc.html
Pat
Schoodic - F36
Beverly MA
Schoodic - F36
Beverly MA
I am guessing this is somewhat dependent on the paint, surface and the kind of rollers used. I recently painted my 28' and it took one gallon of Iterlux ACT, with a little leftover to do my 8' dinghy as well.
300-400 sqft per gallon. Depends on application method.
Spraying in the wind - paint doesn't go as far....
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
3/4 per coat for my F-33. Did 4 coats...
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
I just did my bottom on my F35 (P) - I used a calculator I found online based on length and beam - it was right on - I used 2 coats of Pettit Trinidad HD - used a little more than 3/4 g per coat. Yours is probably .7 g per coat I think. ( don’t know where the calculator is !)
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
1999. Wing Keel 5’
Emery Cove, CA
