Electrical Panel Meters
TonyB
Post by TonyB »
Hey folks,
purchase almost complete on my new to me 97 Freedom 40/40 "Circe". I am wondering if anyone has had to replace any of the electrical meters on the panel? Both my DC meters are shot. I have contacted Bass, the panel manufacturer, but they have not responsed. I am pretty sure these should be some standard sized meters that are available but if anyone has done this any info would be helpful.
Tony
SV Circe 1997 Freedom 40/40 - Hull #20 - Brickyard Cove Marina, Richmond, CA
rvivian
Re: Electrical Panel Meters
Post by rvivian »
Hi -
Have a look at: https://www.bluesea.com/
RadioZephyr
Post by RadioZephyr »
Bass sells meters and shunts through their website, but they may not fit their older panels.
https://www.bassproducts.com/meters/
After a lighting strike I had to replace one of my 12V meter. I obtained them from Bass. Here's the info:
Analog Meters [3.5"] 140-3532-016 Type: 8 - 16 VOLTS DC 1 $59.40 $59.40
TonyB
Post by TonyB »
Thanks all for the info.
Tony
Tmack
Post by Tmack »
Tony did you find a good replacement for your meter?
My Bass analog voltmeter is not too helpful if I want an accurate reading. I see plenty of interesting volt/amp combos online, there must be some that would fit in that same spot.
Thanks. Tom
Tom
F32 "TnT" Hull #11
Rye NH USA
Tricia
Post by Tricia »
According to their website, Bass Products is no longer in business.
jamesorr
Post by jamesorr »
As a previous poster noted, I also used a Blue Sea Systems Mini OLED Voltmeter to replace my Weems & Plath one that went bad -- not a perfect fit, but used a bit of plastic cut to the right size to mount it on -- works fine.
Sailing-61-North
Post by Sailing-61-North »
Ditto on Blue Seas. In the process of stripping all the electrical and starting over with Blue Seas panels and all new marine grade wiring.
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
