Hatch Solar Vent
Hatch Solar Vent
Postby philipl » Wed Jun 05, 2019 5:21 pm
I have an ICP SolarVENT installed on main cabin hatch that is no longer working. It has a 5 inch opening. This model is no longer available. All the newer solar vents fit a 3 or 4 inch opening. Is there anything available to slot into my 5 inch opening or perhaps one that comes with an adaptor. Looking for an easy solution.
Philip Leahy
F-38 ex Manchester, MA.
philipl
Re: Hatch Solar Vent
Postby JohnReinagel » Thu Jun 06, 2019 11:29 am
Hi Philipl, I don't know if this is the same reason yours has failed, but a bunch of years ago mine did too. I found that the rechargable battery within completely died (probably shorted) and even in bright sunlight the fan would not spin at all with the battery installed, the vent seemed completely dead. I happened to have a rechargable AA battery on hand so I swapped it out, wala, fan started working again. Give it a try if you haven't already, check the battery size first of course.
John
1984 Hoyt F32
Hull #53
JohnReinagel
Postby philipl » Tue Jun 18, 2019 2:55 pm
Unfortunately the electronics were also corroded.
Still looking for a 5 inch alternative.
Philip
Philip Leahy
philipl
Postby kvw613 » Fri Sep 06, 2019 6:16 pm
Do an Amazon search.. Many of the Chinese ones have 5 inch holes.
kvw613
