Quantum 2 Radar for F28
Hello Freedom Friends! I have a 1987 Freedom F28 and am installing a Raymarine Quantum 2 radar to a post on the port side of the boat at the transom/rear of the cockpit. At what height above the deck should the radar be installed that will provide the optimum performance? Thank you for your advice in advance. Ken Woodward of the F28 sailing sloop "Inevitable".
- GeoffSchultz
Re: Quantum 2 Radar for F28
High enough so that the beam doesn't hit the boom, even when running downwind and the boom isn't parallel with the water.
Thank you Geoff.
Hi Ken, hoping you can post pics/suggestions on your radar pole install when it's done....planning to do the same thing on my F28. thanks,
Walter
Walter
Walter Gotham
Salem MA USA
Salem MA USA
I've used this Edson tower for 10 years with success. It wasn't a major install. Edson part #674.
- dome
- IMG_2907.jpeg (1.17 MiB) Viewed 6058 times
- rail support
- IMG_2906.jpeg (2.1 MiB) Viewed 6058 times
- Base,
- IMG_2905.jpeg (1.95 MiB) Viewed 6058 times
Stephen Lee
Salacia
F35 Pedrick
Marblehead MA and Rockland ME
Salacia
F35 Pedrick
- GeoffSchultz
Here are some photos of my radar installation, which is on a 40/40, and probably overkill for a F28, but you have to think about the forces that a radar on a pole will generate if you're pounding into a seaway. The photo of the boom and radar isn't the greatest, but I don't have many from an angle where you can see both at eye level. Note, that this is my old radar pole and the newer one is higher, as this one was too low. I think that I probably added a foot. Also, note that there is a connection from the radar mast to the top railing to add stability.
- 20200105_182735-2.jpg (16.75 KiB) Viewed 6056 times
