Leaky Gudgeon Bolts
Sailing-61-North
Leaky Gudgeon Bolts
Post by Sailing-61-North »
So one of my issues I need to fix while the boat is on the hard is the "Wallowed Out" bolt holes. Looks like original from 1981.
On the inside I was considering roughing up the fiberglass, creating a dam and pouring some slow cure epoxy (Table Top Stuff - up to 4-inch pours) to "Fill the Void" back there. BAD IDEA???
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
SV_Pyari
Re: Leaky Gudgeon Bolts
Post by SV_Pyari »
I find myselfe to have a similar problem. While underway in light sailing some water find its way from the transom area into the bilge.
The only suspects are the lower gudgeon and its bolts or the bolts holding the sterntube.
Are your gudgeon bolts in the bilge/transom are? Hard for me to get a good loock since a modified diesel tank is blocking my view. And it also seems to be a solid area with epoxied play wood in between (check picture)
2022-06-22 14_15_46-Photo - Google Photos.jpg (118.44 KiB) Viewed 197 times
Or it might be the sterntube bolts, since I had them loosened last winter while installing a new prop.
2022-06-22 14_14_38-Photo - Google Photos.jpg (120.83 KiB) Viewed 197 times
2022-06-22 14_17_03-Photo - Google Photos.jpg (72.1 KiB) Viewed 197 times
Might as well reseal all of them.
I am welcome to any suggestions.
Manuel
SV Pyari - F30 CK, centerboard, wishbone booms, wraparound sails.
Built in UK by Fairways Marine. Hull #110
Sailing-61-North
Last summer, before taking the boat out of the water, I climbed-low crawled ect to see. I removed the hot water heater which made it easier. I was thinking the packing gland but ruled that out. Next was the stern tube but once I got back there it was obvious the grudgeon bolts were the culprit. Righr now is the time to fix since the water heater is gone along with the motor. Lots of room to fix things - kinda of.
S/V Arctic Tern
Freedom 33
1981 - #37
Salacia
Post by Salacia »
Another source might be the just above water line thru hull drains. Exposed constantly they can crack and leak. Worth checking even if they aren't the culprit. They have a 15 to 20 year life.
Stephen Lee
Salacia
F35 Pedrick
Marblehead MA and Rockland ME
Sailing-61-North
Sorry I haven't gotten any photos. Will do so tomorrow when I head down to the boat...
S/V Arctic Tern
Freedom 33
1981 - #37
RadioZephyr
Post by RadioZephyr »
What’s that pipe/tube thing next to your propeller?
SV_Pyari
Post by SV_Pyari »
It is a cable protection for an older sonar/fish finder and will eventually be removed.
Last weekend i was inspecting the leak further while under sail and found the culprit.
I was crawling head first into the portside storage locker only to discover the leak right in front of my eyes.
The cockpit drainage (square hole through the transom above water line) was badly laminated on the bottom side. Only one Layer of fiberglass which apparently did not stick all the way to the side. From the outside it was covered with gelcoat. Now the gelcoat got a crack right on the spot that always has a bit of water remaining in the drainage. So every wave splashing into the drainage will leave a bit of water, which seeps through the crack into the bilge.
Never would have thought the leak would be there since it looks very solid from the outside.
Will "seal" the crack with duct tape for this season and repair it properly over the winter.
Sorry for crashing this thread.
Manuel
Sailing-61-North
I got sidetrack the last few days. Shiney red thing showed up today. Will take a few photos soon.
S/V Arctic Tern
Freedom 33
1981 - #37
SV_Pyari
Post by SV_Pyari »
Looks beautiful! Congrats!
Manuel
