Replacing the shift cable on F38
Posted: Mon Aug 01, 2016 4:03 pm
The shift cable snapped on me just as I was pulling up to a mooring. I drifted on...lucky for me. I took the Edison binnacle apart and noticed that the cable broke just below the connector to the shift lever. Luckily there was sufficient thread left on the cable for me to re-thread the cable back into the connector. I made some minor adjustments at the gearbox end to allow for the slightly shorter cable.This will probably be sufficient for the balance of this season. However I would like to replace this cable. Any particular tricks to this job eg how to feed the cable up through the pedestal. Someone suggested putting a female fitting between the old and new cable and pull them through together. Do you pull the cable up through the [pedestal or down through the pedestal? Is the length standard for this boat?
