Freedom 44 Emergency Tiller and Anchor Chain Locker Drainage
rbrown739
Post by rbrown739 »
Looking for some information on two topics; Emergency Tiller, and Anchor Chain Locker:
Emergency Tiller
1. Where and how do you stow your emergency tiller?
2. What does your emergency tiller look like? Mine is roughly 5 ft long with a welded on perpendicular tube at one end about
2.5 ft long
Anchor Chain Locker
1. How do you drain or remove water that gets into the chain locker?
2. What is underneath the chain locker floor?
Thanks for any help or pictures.
Bob
SV Windwalker, Freedom 44, #20
Goose13
Re: Freedom 44 Emergency Tiller and Anchor Chain Locker Drainage
Post by Goose13 »
I bungie cord my tiller to the mizzen mast down below. That way it is easily accessible and out of the way. Not sure how a 44 is set up. But down below on my boat the mizzen is in the galley and I bungie anything 6 feet (2x fishing poles and a tiller) And some what skinny.
Doug and Marie
Millennnium Falcon F33 CK cb #4
1980 wish bone booms Electric Drive
BillSmith
Post by BillSmith »
35' Pedrick here.
Our chain locker has two drains, water would be able to flow on either tack at sail. There are obvious holes that are tubed to forward hole ports around the water line. Assume you'd have same?
We store our emergency tiller in deep storage lazarette behind wheel. Size isn't as robust as yours and our tiller is more of a two-piece pipe structure.
Bill & Carole Smith
Freedom 35 Pedrick
SweeTART
Coyote Point
San Mateo, CA
