Don't know. Hr meter was not hooked up when I got the boat. Today I made a simple 3-D to sit in place. I will use (removed from yanmar) the existing mounts and see where things fall. I have the "sump and tyranny" shown here.. Mounts are on the boat and I'll mess with that tomorrow when I go to town.. You will note the board say Beta 25. I may have to go that route due to aft mount complications. I will make a similar 30 model and see how it goes.
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Looks like Fairbanks weather. Coastal Alaska is usually more temperature friendly given the latitude. 10 degrees F outside right now and that's cold for us. Usually we just get buried in snow. Watch the below attachment - I live at the other end of the canyon.
Sailing 61 - wow what a video! You have the snow trophy hands down! Today was 3 degrees and felt balmy…. Keep up the great engine work! I can’t wait to get back to sf bay and sail- this week.
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
Yep 2.8 farahieth and guest winds 60 - 109. Gota live Alaska.
As for snow. Its what happens when you live in North America's northern rain forest - Prince William Sound. Here's a good video of my back yard... https://youtu.be/HWwKkIjsizs
S/V Arctic Tern
Freedom 33
1981 - #37
Here is my area of issue - the aft mounts. To fit the 30 I will have to bump the motor forward 4-6 inches approximately. The 25 will fit better but I loose a little hp.
Shown below is the 25. I have the old "drop down " brackets that may work. You will also note the mounts are almost up against the hull.
The 30 is almost 2-inches wider and would protrude thru the hull.
S/V Arctic Tern
Freedom 33
1981 - #37
Re that video that you linked: Sue & I met Tony Flemming on Venture when we were going down the St. Lawrence. We shared several marinas as we worked our way down. We're still friends on Facebook. Nice guy!
