Mark, your prop looks so beautifully clean. Wish mine were likewise. I’ve had disappointing experience with Pettit’s sink prop paint. What do you use, and how?
Dale
Prop Suggestions for 28M
Re: Prop Suggestions for 28M
F32 Hull #67, Saybook CT.
- RadioZephyr
One other advantage that came to me about the max prop is the outstanding performance in reverse. The blades go into a much more optimal position when reversing than a fixed prop, and the result is that you can really feel it bite when backing down. A couple seasons ago I was operating a friend's F38 that has a fixed 3-blade prop, and when I shifted into reverse and hit the throttle the response was much "mushier" than I was used to. There was a considerable delay before the boat did what I expected it to do. I'm sure that with some experience this difference could be completely accounted for and anticipated, and an operator would have no trouble docking the boat in the same distance. Still, I really like having that kind of stopping power in my arsenal. It makes the boat feel tight and responsive when maneuvering.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
Sunset Spy
F38, Hull #152
Boston, MA
Hi Dale- This was done by the yard shortly before I purchased the boat. The bottom paint was Micron CSC. The prop paint isn’t listed but it sure looks like it was Pettit zinc spray. I know that has a history of clogged nozzles but it seems to have kept growth off for at least this season…
Mark
Thanks Mark. With no better prop protection alternatives simple and inexpensive enough for me to try, I’ll probably give Pettit another chance. Reluctantly.
Appeal to Heaven was hauled out last week and I found four tip of finger sized barnacles on the prop. I think that may have been the problem. It seems like their are lots of up votes for the Maxi-prop, so I will lubricate , check the pitch, and zinc paint it in the spring. Then I will make sure to keep it brushed off with some summer swimming.
Thanks for all of the input.
When I was struggling to find the answer to the same question I found this article and the charts it contains useful.
https://www.yachtingmonthly.com/gear/fo ... test-29807
Cheers
Rafa
Cheers
Rafa
Rafael
s/v Nausikaa
SSR 30570, sail GBR 4619L
s/v Nausikaa
