Hi all -
I purchased a 1987 Freedom 30 a few weeks ago (A terrific and past due upgrade, after having a F-25 for 25 years). I wasn't there for the survey and am going through the report that includes the following:
"Corrosion and possible leak observed where the engine exhaust exists the transom [Figure 12.14]. Monitor for leaks after launch with engine running and repair if necessary. Clean and treat corrosion."
I've attached the survey photo that shows the elbow with rusty liquid dripping from it.
Please...
- Do I go through the port lazarette to access the elbow?
- There is a round plastic white cover mounted on the horizontal area at the stern side of the cockpit, just inboard of the stern railing. Looks like it has two indents where I could insert a slotted head screwdriver to pry it open. What is that cover and does it open?
- If the elbow should be replaced, where might I purchase a replacement?
Thanks!!
Replace Exhaust Elbow? - Freedom 30
- F30 exhaust elbow.jpg (62.01 KiB) Viewed 216 times
Re: Replace Exhaust Elbow? - Freedom 30
Congrats! Just sold my F30 a few years ago. There are two options to access the lazarette/inside transom area depending on where you’re trying to go. One is through the cockpit locker, if you’re trying to get to the port side of the rudder shaft. On the starboard side (where the shore power connection was on my boat) the aft bulkhead of the quarter berth will come out by removing the perimeter screws.
The cover on the top of the transom is to access the top of the rudder shaft and is where the emergency tiller attaches.
1985 F39 Express (Hull #44)
S/Y OXYGEN
Port Washington, NY
S/Y OXYGEN
Port Washington, NY
Congrats on the "new" boat" I think you're gonna love it. I have a F38. The exhaust elbow and its connection to the outside are hinky on the Freedoms (note the white caulking holding it in place) so this is as good a time as any to fix this. That elbow itself should be replaced (not "repair" as the survey language suggests). With that much rust you are likely to be exhausting hot water and carbon monoxide in your boat especially if there's a known leak. You should always check that water is coming out when the engine is running. The exhaust hose is accessible -- not easily, mind you, if you're a big person -- through the port locker. If you're pulling everything off (my approach to boat work) you might consider replacing the exhaust hose too especially if it's looking kinda worn. The exhaust port on the transom is low to the water and should be easily visible standing on the dock. I recommend you do this work when you're on the hard. You might also look at upgrading that exhaust port with a check valve. These are all on my To Do list for next time. Do let us know how it all works out!
Kynntana, Freedom 38
Hi Stephen and thanks for the helpful info! I should have figured that the stern berth aft bulkhead would be removable, and I need to dive into the port lazarette to give it a good cleaning so will explore that area then. From your post, I'll also look for an emergency tiller!!Stephen_H wrote: ↑Sun Sep 17, 2023 12:28 pmCongrats! Just sold my F30 a few years ago. There are two options to access the lazarette/inside transom area depending on where you’re trying to go. One is through the cockpit locker, if you’re trying to get to the port side of the rudder shaft. On the starboard side (where the shore power connection was on my boat) the aft bulkhead of the quarter berth will come out by removing the perimeter screws.
Appreciate it, Steve
Hey Gamayn, thanks for the helpful info! Yes, already love the F30 and have had some fun and fast sailing, plus an overnight. Also happy with the systems and interior, but there is a fair amount to improve.gamayun wrote: ↑Sun Sep 17, 2023 4:58 pmCongrats on the "new" boat" I think you're gonna love it. I have a F38. The exhaust elbow and its connection to the outside are hinky on the Freedoms (note the white caulking holding it in place) so this is as good a time as any to fix this. That elbow itself should be replaced (not "repair" as the survey language suggests). With that much rust you are likely to be exhausting hot water and carbon monoxide in your boat especially if there's a known leak. You should always check that water is coming out when the engine is running. The exhaust hose is accessible -- not easily, mind you, if you're a big person -- through the port locker. If you're pulling everything off (my approach to boat work) you might consider replacing the exhaust hose too especially if it's looking kinda worn. The exhaust port on the transom is low to the water and should be easily visible standing on the dock. I recommend you do this work when you're on the hard. You might also look at upgrading that exhaust port with a check valve. These are all on my To Do list for next time. Do let us know how it all works out!
I'm liking your input of going ahead to replace the exhaust elbow and will do that after haulout, and maybe also the hose. Will also take a look at the funky caulking. Hope I can find an elbow replacement. Please let me know if you have any idea where one can be located.
We check the exhaust port each time we start the boat by looking over the stern rail, but thanks for mentioning. I've told the other users to shut her down immediately if they don't see the water exhaust.
Thanks for the advice!
FYI - the emergency tiller is just a welded “L” of thick aluminum tube (like 3” I think). So don’t look for anything fancy.
S/Y OXYGEN
Port Washington, NY
S/Y OXYGEN
Port Washington, NY
