Camber spar too long?
Re: Camber spar too long?
I’ve noticed while rigging mine that it goes on much more easily if the curve of the spar is oriented upwards. Hope it helps.
1984 F32 Hoyt hull #41
Port Dalhousie, Ontario
It took me a few years to figure this out on my 40/40 #16. I attach the camberspar to the aft/mast end of the the camberspar first, raise the jib, run a small heavy twine through the grommets to the bow rail, pulling the sail forward until I can get the bolts through the grommets and metal clip. The key is raising the sail most of the way.
Jim Lo Dolce
Lo Dolce Vita VII
Freedom 40/40 #16 1995
Lo Dolce Vita VII
