F36/38 mainsail area
Postby Belanich » Tue Apr 16, 2019 5:04 pm
Does anyone know the sail area of the f36/38 mainsail? I've been getting quotes for a new mainsail and the sail area varies greatly.
Michael Belanich
Dolcetto 38 no. 65
Belanich
Re: F36/38 mainsail area
Postby Camino » Tue Apr 16, 2019 6:47 pm
Have you looked at sailboatdata.com
Freedom 36 in above url show total sail area at 685.00
Freedom 38 in above url show total sail area 572.00
Seems about right as the foretriangle is small
Mack sails built us a new main on the Pedrick 35 with huge roach main. Came in perfect .
Maybe I have the wrong boats. My bad if I do.
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
Camino
Postby Belanich » Tue Apr 16, 2019 9:27 pm
I looked at the sailboat data website and it is very inaccurate. The posted sail areas are calculated from P and E dimensions without considering the huge roach our mainsail have. Their mainsail area is posted as 377 sq ft! My all my quotes have mainsail areas that range from 475 to 575.
Belanich
Postby RadioZephyr » Wed Apr 17, 2019 8:56 am
Here are the accurate measurements for Freedom sails:
https://www.dropbox.com/s/ab0i11kz96bue ... s.pdf?dl=0
Josh
Sunset Spy
F38, Hull #152
Boston, MA
RadioZephyr
Postby Belanich » Wed Apr 17, 2019 11:43 am
That's fantastic - thanks. I did not have the info in my documentation on the boat. Of course the next question is - should I increase the mainsail area? I sail on Long Island Sound so I typically have light wind and I'd like more horsepower. If I go with a squaretop sail there is a 100 sq ft variation in sail designs. Has anyone pushed the limit with mainsail size and are you happy with it?
Thanks again,
Michael Belanich
Belanich
Return to Rigging and Sails
Users browsing this forum: No registered users and 4 guests
