F32 reefing
F32 reefing
I’ll try to post a photo. My question is.......
At my reefing points on the sail there are two much smaller grommets slightly below and to either side of the line hole. Can anyone tell me what theses are for??
- B3636964-5C34-4166-837B-FBD506ABEB9F.jpeg (179.57 KiB) Viewed 6426 times
1984 F32 Hoyt hull #41
Port Dalhousie, Ontario
Re: F32 reefing
They look like the holes for the leech line. It's normal to bring the leech line out to a small jamming cleat which would be mounted between those two holes. But they wouldn't usually go right through the sail and you don't appear to have a leech line.
Sold for health reasons
Re: F32 reefing
I do have a leech line. These holes are toward the luff. There are a pair of them right below each reef crinkle.
- JohnReinagel
Re: F32 reefing
Alan, do you have a picture of the same area further away so we can see more context? I do not think those are for a leech line as they would be at the leach of the sail running perpendicular to those grommets, I don't see a leach near that area in the pic either. No offense intended Andygc. Loose footed sails (not certain you have that or not) will often have a grommets that you would gather the reefed portion of the sail with line to tidy it up over the boom, not around the boom. However, the grommets you show are not in line with the reef cringle as they often are for the purpose I mentioned. Maybe a wider view will give better context.
John
1984 Hoyt F32
Hull #53
1984 Hoyt F32
Hull #53
Re: F32 reefing
I have the same holes in my sails on a 39 Express. I run bungee cord through them to act as a retainer to keep the reefing hook from the single line reef system from coming out.
- JohnReinagel
Re: F32 reefing
Yes, I bet you are correct. I actually need then on my sail to stop the hook and block from falling out as well as stop it from spinning causing a twist the the reef line. It's quite annoying.
John
1984 Hoyt F32
Hull #53
1984 Hoyt F32
Hull #53
Re: F32 reefing
I had to severely crop the photo to get it to upload. As I mentioned earlier these are at the luff in line with the reef cringles. There are four of the large grommets spaced up the luff and each has the two smaller ones below. I did not get any hooks from the previous owner. The reefing lines were run up and through the large grommets then back down to the mast base and on back to the cockpit.
Re: F32 reefing
Absolutely no offence taken. I'm sorry, but it is difficult to see what part of the sail that is. You should not need to crop photos, but you do need to resize them (reduce the resolution). There are instructions about that on the forum.
- JohnReinagel
Re: F32 reefing
Alan, I can't imaging how much friction was created by the lines running like that. My guess is the system would not have been very useable without the block in the mix. As I think about that set up, let's focus on the first reef line. If it exits the forward end of the boom on the startboard side, runs up the sail and through the grommet back down to the forward end of the boom, the line would need to run into the boom on the port side and then back. Is that how it was run? With a reef hook on a block the line is always on the same side with the exception or running through the reef cringle grommet on the leech just before it's tied to the boom.
John
1984 Hoyt F32
Hull #53
1984 Hoyt F32
Hull #53
Re: F32 reefing
Yes John, that’s exactly how it was done. There is a lot of strain at the luff cringle . That’s why I sought help here, it seemed to me that something was amiss in my setup. I makes way more sense with the hook and block.
