Is this a G10 rig?
Re: Is this a G10 rig?
Working on the running rigging. Main sail shown with a triple reef.
- Compress_20220618_134908_8246.jpg (153.12 KiB) Viewed 2146 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Sails look beautiful! And you don’t have to worry about sail slugs- sweet!
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
1999. Wing Keel 5’
Emery Cove, CA
Biggest issue so far is what I used for "lacing". The top has a few section of 1-inch webbing. Not the best stuff - strong as heck but alot of friction on the mast. I did get parrels beads but got the wrong size. Will be replacing with larger beads and line.
Right now just figuring out the reefing lines. Currently have it as slab but considering changing to separate fore/aft lines. Too much friction as one line. Will have to get more clutches if I go that route. I also wish the 1st reef was at a different location in-relation to the wishbone chocker. Will play with that also. I have time. Motor is not leaving San Fran until maybe this coming week and who knows how long to get to AK...
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Look gorgeous! Re lacing line, doesn't need to be very big, 6 mm is more than enough, and 6-8 loops around the mast would suffice.
Rafael
s/v Nausikaa
SSR 30570, sail GBR 4619L
s/v Nausikaa
May replace what I have with some 1/4" inch (6-mm) Dyneema... The bigger stuff does catch and jam.
The motor finally arrived in San Francisco and is going through customs. Hopefully it will show up here in a couple of weeks. Once the boat is back in the water I will take more pictures with the sails up.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Motor is here. See viewtopic.php?f=64&t=13147 for that show.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
So.... what´s the outcome of all that effort? have you been out?
Rafael
s/v Nausikaa
s/v Nausikaa
Shooting for next summer. Work keeps getting in the way. One more year..........
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Update to work... Retirement scheduled for 1 May 2023... Maybe then I will have some free time.
In the interim I have began to clear the decks, pulling the sails and running rigging in preparation for winter. We are getting out termination dust right now.
- 20220906_130434.jpg (3.26 MiB) Viewed 1701 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Been updating my other post "And it Begins". Getting ready to finalize motor install.
- Compress_20231018_141259_9984.jpg (446.61 KiB) Viewed 505 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
