Is this a G10 rig?
Re: Is this a G10 rig?
Will not be till April before I have them on the boat.... Winter..
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
2 points — sails are perfect! Next, how do you keep the floors spotless with all the muck outside?
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
1999. Wing Keel 5’
Emery Cove, CA
Daily cleaning chores....... The down side of a large Fire Station with only 3 guys on duty. Somedays it feels like that is all we do.
As for the sails. Will have a better idea once I get to raise them. I might get a break in March to experiment.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
By the way thanks a ton for your help - it was very gratifying.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Sails look great! And you are most welcome. Glad I could be of help.Sailing-61-North wrote: ↑Sat Jan 22, 2022 3:03 amBy the way thanks a ton for your help - it was very gratifying.
Rafael
s/v Nausikaa
SSR 30570, sail GBR 4619L
s/v Nausikaa
Main sail. Working on the lacing but the wind kicked up. The roach isn't too much.
- Compress_20220518_122122_2729.jpg (202.17 KiB) Viewed 1834 times
- Compress_20220518_122121_1471.jpg (209.84 KiB) Viewed 1834 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Gorgeous. Congrats!! When are you casting off?
Rafael
s/v Nausikaa
s/v Nausikaa
Ha I wish. My beta block is stuck in Japan. Once it makes it way to the UK and get assembled it will be enroute to San Francisco. AND once it is there it gets trucked to Alaska..... I bet end of July.....
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
Of course... they are Kubota engine blocks!! Yeah... Betas are lovely little engines, but customer service could certainly improve. I need to import spares for mine directly from UK, as there are no distributors in Spain. Still, right now logistics for anything is all upside down. No matter, guess there´s still lots to do on Artic Tern before mid July to get her "ready"!Sailing-61-North wrote: ↑Thu May 19, 2022 1:13 pmHa I wish. My beta block is stuck in Japan. Once it makes it way to the UK and get assembled it will be enroute to San Francisco. AND once it is there it gets trucked to Alaska..... I bet end of July.....
Rafael
s/v Nausikaa
s/v Nausikaa
Oh yeah too many projects. The bummer is I took all of May off from work to get the motor installed. I have been doing things here and there but I will now have to spend a few hours after work each day once the motor shows up.
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
