I have a Hoyt gun mount spinnaker pole on my Freedom 32. I love using it, riding the bronco!
The problem is that the pole just kind of hangs there where not in use.
For hurricane season I usually lash it to a stanchion for stability...and had a makeshift chock that ultimately broke over a few years.
How does anyone make the aft end secure when the pole is retracted and not in use. The front stays really secure in the sleeve in the pulpit. I would love to see or hear any ideas, ways to secure it, chocks...anything.
F32 Hoyt Gun Mount Pole - How do you secure it?
Scott Forgey
Girlfriend
Freedom 32 Hoyt #81
Girlfriend
Freedom 32 Hoyt #81
Re: F32 Hoyt Gun Mount Pole - How do you secure it?
I use one of these on my Freedom 25:
https://www.westmarine.com/buy/forespar ... 63_004_511
Here is a context shot from my boat:
- Screen Shot 2020-08-02 at 6.07.41 PM.jpg (38.11 KiB) Viewed 2191 times
1984 round-mast Freedom 25
Thanks, everyone.
The pole on the Freedom 32 is 4", so someone's suggestion to get davis adjustable rubber one worked! $11 Amazon.
All set...see how this goes next month when I return home.
cheers,
cheers,
Scott Forgey
Girlfriend
Freedom 32 Hoyt #81
Girlfriend
Freedom 32 Hoyt #81
Do you have any pictures of your pole rigged in use and do you need /rig a backstay
Not used mine yet it is supported at the back by a stainless u shaped bracket fastened on the outside of the stanchion the front stops in the gun mount
