rig a spinnaker f32/33
Bill
Post by Bill »
New boat to me freedom 33/32 1987 depending on who you ask
Can anyone supply a full drawing or explanation, for setting up the spinnaker
I have a sail in a bag a shute and some sheets but do not know how to rig it all not sure if I have the Shute leads
Bill
Grimsby_Alan
Re: rig a spinnaker f32/33
Post by Grimsby_Alan »
I believe there is a drawing of the rigging in the manual that is posted on the forum.
Also if you look around a bit you can find Rick Simmonds excellent write up on setting, using and dousing the spinnaker.
Good luck
1984 F32 Hoyt hull #41
Port Dalhousie, Ontario
mike cunningham
Post by mike cunningham »
Not clear if you have a gunmount, If you do, Rick Simmonds guide is indispensable.
viewtopic.php?f=16&t=8551
Mike Cunningham
Freedom 30 (Mull) Hull #3
Bill
Post by Bill »
Thank you
