double skin/sail
hatuey
double skin/sail
Post by hatuey »
double sails,
Hi, I'm going to set my sails for the first time on my Freedom 35 cat ketch, original sail system.
would any of you have a little drawing explaining how to put the sails around the masts?
sous voiles.jpg (81.56 KiB) Viewed 2043 times
andygc
Re: double skin/sail
Post by andygc »
Have a look at the Freedom 33 manual here: viewtopic.php?f=16&t=68
Sold for health reasons :(
andygc
Post by andygc »
My 30CK is rigged the same. This is how I fold the sails for rigging:
Fold sails.jpg (28.56 KiB) Viewed 2033 times
That is, roll each side separately to the middle. Stand the roll up in front of the mast, inside the wishbone, and then just unroll each side. When you discover you have the roll upside down or facing the wrong way, swear, and start again. ;)
arrancomrades
Post by arrancomrades »
Hardest bit is getting the wishbone to saddle strings done. Tie the sail bundle so the holes are accessible and tie the front wishbone-end close to the back mast. Backsail is less of a trial. Maybe do it first as a learning exercise. And not in a breeze.
Mike Johnston
hatuey
Post by hatuey »
merci
pour votre aide
je sent que ca va etre compliqué la premiere fois....
savez vous si il y a d'autre Freedom (a part moi ) en bretagne, France.
merci
bonne journée...
Castaway
Post by Castaway »
Cher Hatuey,
On veut avoir une assistante pour vous aider!
Bonne chance!!
Gerald
Gerald Freshwater,
Lerwick Boating Club
Shetland Isles, Scotland
