Left side is the "Fore" segment with a single block. The right side is the "Aft" segment with a double block. Both are Schafer #7. Ignor the poly, it's my messenger lines for the winter.
If you are referring to the open spot behind the single block then yep I might place another spare line there when I get up to inspect with the man lift.
Mast split
Re: Mast split
- Main Top View 2 Drone smaller.jpg (738.95 KiB) Viewed 931 times
S/V Arctic Tern
Freedom 33
1981 - #37
Prince William Sound - Alaska
Freedom 33
1981 - #37
Re: Mast split
Other side view and yes as far as I know it's the original mast.
- Main Port View Drone 50%.jpg (521.05 KiB) Viewed 930 times
S/V Arctic Tern
Freedom 33
1981 - #37
Freedom 33
1981 - #37
