My freedom 33 mast doesn't have brothers at the cabin top only a thin fibreglass ring slightly narrower than the hole which is simply held in place with self tappers
The cabin top at this point is about 3 in thick where the mast is wedged
As I am replacing my mast as it snapped at the cabin top should I add brothers
Mast brothers
- RadioZephyr
Re: Mast brothers
Yes. I’d also recommend putting some sisters in there too while you’re at it.
(I think you might mean partners, but I’m not entirely sure.)
Josh
Sunset Spy
F38, Hull #152
Boston, MA
Sunset Spy
F38, Hull #152
Boston, MA
Re: Mast brothers
I'm curious how your mast broke. That "thin fiberglass ring" doesn't sound like the aluminum ring that is through bolted on deck for the Freedom 30/36 that I am aware of. Because the mast is so bendy, I would think the wedge that goes between the mast and the deck structure should also be flexible/compressible and not made of wood. As to partners, my F38 does not have any that I can see but I suspect something rigid might have been laid down inside the fiberglass to strengthen it, but I don't know this. The mast sits on a "tophat" at the base and I believe most of the forces are downward while under sail, but I'm also not a engineer so this is a wild guess on my part. You might want to get a shipwright's input so you get this right. Those masts are not meant to be replaced too often....
Kynntana, Freedom 38
