mast wedge help
Re: mast wedge help
we used standard west system and when it finally was necessary to remove the stump from the base because the mast broke in half . it popped right off with hand tools
- arrancomrades
Re: mast wedge help
Hello,
I have a 'second batch' UK F35 CK with alloy spars. My deck seal looks very like: Post by patrick@paradox » Tue Mar 07, 2023 11:17 am (above). The rubber was damaged the first time I took the mast out but I was able to buy an 'off the shelf'' strip online - Heaven knows where from. While being nominally a rectangular section, it's actually slightly thinner on one edge so this goes down. Waterproof grease on both sides. The deck ring pulls it into position as the bolts are tightened.
The bottom is in an 'ashtray' ring and is described in the well-known typescript which says to glue it in with Plastic Padding - a relatively cheap epoxy. The trick, which I found the hard way, is to put some kind of soft filler at the bottom of the gap - I use polystyrene waste - so that when you need to destroy the PP with a drill and chisel, you're drilling into a void. Also, when removing, carefully mark all positions and measure as well, then preserve some of the thinner bits of PP to provide an exact match to how it came out - a quarter to a third of the circumference is enough.
Maintain a bag of small wooden wedges, maybe 3"" to 6"" in length (75mm to 150mm) for all ins and outs.
If anyone has had unusual noises from an alloy mast, please send me a message.
Mike Johnston
Re: mast wedge help
Hoping that my explaination is sufficient. I'm of the mind that the small hat top fitting at the keel and the wooden wedges on deck aren't the best way to hold this mast in place, and I'd like to be much more confident that my mast will stay in place during heavy weather.
I wonder if anyone has come up with alternatives or supplements, perhaps an additional fitting on deck similar to what you see in a mast hinge or maybe a two part clamping system bolted to the deck (with sufficient backing plates) which would provide additional support for the mast another foot or two above the deck. I have an F25 but think this would apply to any other Freedom free standing mast.
Re: mast wedge help
My 2nd question. For my 1984 F25 I'd like to replace the wooden wedges (which have taken a beating) with newer "plastic" ones. Here is the ordering page https://rigrite.com/Spars/SparParts/Mast_wedges.php Does anyone know what sizes I should be ordering. It says to measure the gap but I won't be able to do that until the mast is being stepped and I'd prefer to have everything in hand. Can't exactly place an order while the yard is holding the mast in place. Thanks in advance.
- RadioZephyr
Re: mast wedge help
What exactly are you worried will happen to your mast in heavy weather? I’ve never heard of a Freedom mast failing because it was insufficiently held by the mast partners and/or the top hat. That is, as long as it wasn’t one of the earlier boats that hasn’t been retrofitted.Serenity wrote: ↑Thu Apr 27, 2023 5:40 pmI'm of the mind that the small hat top fitting at the keel and the wooden wedges on deck aren't the best way to hold this mast in place, and I'd like to be much more confident that my mast will stay in place during heavy weather.
Some of the earlier Freedoms were not built with the transverse bolt going through the bottom of the mast, which fits into a channel in the top hat to keep the mast from rotating. Instead, they solely relied on a large stainless L-shaped bracket that was bolted down to the mast step, and the side of the mast. I believe the purpose was primarily to index the mast, and secondly to prevent its rotation. Turns out there were more rotational forces on the mast than they had initially expected, and it’s better for those forces to be balanced, rather than on just one side. That’s when they came up with the top hat with channel and bolt design.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
Sunset Spy
F38, Hull #152
Boston, MA
- RadioZephyr
Re: mast wedge help
Here’s the bracket on my last boat, which was built in 1986, hull number 25. One of the previous owners had the top hat retrofitted so it had a channel in it for the bolt, but for some reason they never actually fitted a bolt (nor drilled the holes in the mast for it).
- IMG_4300.jpeg (820.42 KiB) Viewed 2799 times
Josh
Sunset Spy
F38, Hull #152
Boston, MA
Sunset Spy
F38, Hull #152
Boston, MA
Re: mast wedge help
Our mast wedge is disintegrating as well and I've been trying to figure out what to do. I found this online and was wondering if anyone else has tried this? If so, any thoughts?
https://custom-rubber.myshopify.com/col ... 1049252361
Thanks!
Riki
Thanks!
Riki
1997 Freedom 40/40 Hull #27
Re: mast wedge help
Adding to my previous post about addtional support for the mast on my Freedom 25. I'm enclosing pictures of the mast "hat" showing the single steel angle bracket which holds the mast in place. I can see where this is intended to keep the mast from rotating, and perhaps even from poppint out but it really doesn't seem sufficient. No thru bolt or channel as mentioned in other posts.
- Mast Hat Underside.jpg (48.83 KiB) Viewed 2694 times
- Mast Hat View.jpg (60.79 KiB) Viewed 2694 times
- Mast Hat Side View.jpg (49.31 KiB) Viewed 2694 times
Re: mast wedge help
Just FYI, about a month ago I sailed a 400 mile solo offshore passage. 200 miles out from SF in very sloppy seas and then turned around and came back. Wind was 5-25knts. The mast was pretty much silent and proved that the noise WAS coming from the partners and not the mast base. This was with the new spartite pour replacing the old urethane wedge.
So while I don’t doubt that a lot of noise issues come from the base, some can definitely come from the partners!
Tony
- mike cunningham
Re: mast wedge help
Sounds like someone is headed East and South for a nice quiet sail this summer. Good luck on the race bug lighter!TonyB wrote: ↑Mon May 15, 2023 7:53 pmJust FYI, about a month ago I sailed a 400 mile solo offshore passage. 200 miles out from SF in very sloppy seas and then turned around and came back. Wind was 5-25knts. The mast was pretty much silent and proved that the noise WAS coming from the partners and not the mast base. This was with the new spartite pour replacing the old urethane wedge.
Mike Cunningham
Freedom 30 (Mull) Hull #3
