Posted by Payne, Doug (doug.payne@…>)
I wouldn’t loose any sleep, from my
research, I am about the second failure out of a couple thousand boats.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Fargo Rousseau
Sent: Thursday, December 08, 2005
2:23 PM
Subject: RE: [freedomyachts2003]
1987 Mull Freedom 28 Rudder Failure
Thank you, Doug, for the details. We are currently sailing our F30 in
some strong gusty weather…down the East Coast. From this group I
understand that this is a rare problem. Will keep an eye on it.
Fargo
F30#12
“Payne, Doug”
<doug.payne@…> wrote:
We will never know what really happened.
The blade is on the bottom of the lake. The “stump” at the point of
exit of the shaft from the hull has shreds of fiberglass cloth about 4 inches
long and shattered fractured glass resin. I have some pictures. It could have
been grounded at some time in its history, I will never know. We were sailing
in 14-16 knots apparent and our lake is prone to significant gusts. It was
dusk, the boat violently rounded up, I thought it was a gust because it felt
like one, however there are submerged islands in the area that are marked by
buoys, I didn’t notice a shudder from striking something, there could
have been one. Got the boat under control and had rudder control, sailed for 5
minutes, tacked, sailed ten minutes the other way on a beam reach, all of a
sudden bammm, no rudder control, emergency tiller was inieffective, assume the
blade dropped off at that point. All very strange. .
Sent: Monday, December 05, 2005
7:44 PM
1987 Mull
Do you think that the rudder had ever suffered a hard grounding?
The F30 rudder and post looks so much more robust than the typical boat of this
size. It is hard to believe (I don’t want to believe) that you could sail
one out of your boat…
Fargo
NARISA F30#12
lioneldmp7
Having searched the archives,
I only find one incident of rudder
failure on Freedoms, a 1987 Mull F30 in August of
this year. I lost
my rudder this weekend, just hauled the boat and
found it sheared off
right where it exits the hull. Talking to Mark
Edwards today, I
understand the shaft is a fiberglass tube. The
rudder lies in 120
feet of water that I am told has visibilty so low,
a diver can’t see
his glove on his hand. We aren’t finding the
rudder. Talked to the F
30 owner tonight, he went with GMT Composites in Bristol RI,
generated a big bill (insurance covered it) and a
custom rudder, foam
blade, carbon fiber shaft, etc. A good but
expensive solution. They
built the rudder from Freedom plans which the
owner had to purchase
from Freedom. Mark today indicated that Freedom
might make one if
they can find the mold out in the yard, but that I
have to talk to
Bob Wheeler the Customer Service manager. He said
among other things
Freedom is a bit friendlier since the new
ownership took over.
Have any of you had experience with Freedom
building parts from
original molds? I am hoping to argue presedent if
that has been their
practice in the past.
Haven’t talked to Paul Dennis yet, but the F30
owner said he really
wasn’t interested in doing this type work.
Have their been
other rudder failures on Freedoms? You 28 owners out
there might want to inspect your shafts for cracks
or deterioration.
Mine was dropped when I bought the boat two years
ago, adjusted and
all was well.
Thanks in advance for your replies.
