AC placement
Posted by tlira5752 (tlira5752@…>)
I put the AC under setee on my 38 because:
Easy to route the condensation drain.
Short path for the circulation pump (Bilge is close by.).
Easy to route at least two of the vents as well as the intake
Seat cushion muffles sound.
Straight shot to the hull for your output thru hull
Access is very good.
Also, remember if you do not have enough airflow through adequate
venting your unit will be prone to icing over.
