The PO of my 36 installed a shelf in the port sail locker along the
hull side to accomodate the reefer compressor and the microwave.
There is enough space there for an AC unit. It is outboard and high
up so that it does not take up any useable space in the locker.
— In freedomyachts2003@yahoogroups.com, “sailsurv” <sailsurv@y…>
Does any know if the hull on a 1987 F-36 is solid or cored below
water line?
The Practical Sailor issue that featured the F-30 review said the
hull was solid below the waterline (on the F-30). I am installing a
a/c unit and need 2 through hull fittings, one below the water line.
Also anyone have any tips on installing an A/C Unit.
I am looking into moving the batteries to under the L-settee area
using the old battery area for the Unit. I wound put it under the V
berth but a have a 40 gal water tank there.
Thanks, Dom Venditto
Posted by weasle baxter (Guardianduck@…>)
RE: cored Freedom Hulls
Freedoms are cored below the waterline. there are a few areas that have been cored, but chances are that you will have to core the t-hull holes prior to installing the t-hulls.
i work at Freedom
Reply-To: freedomyachts2003@yahoogroups.com >To: freedomyachts2003@yahoogroups.com >Subject: [freedomyachts2003] AC >Date: Tue, 25 Nov 2003 15:43:52 -0000 > >The PO of my 36 installed a shelf in the port sail locker along the >hull side to accomodate the reefer compressor and the microwave. >There is enough space there for an AC unit. It is outboard and high >up so that it does not take up any useable space in the locker. > >— In freedomyachts2003@yahoogroups.com, “sailsurv”
wrote: > > Does any know if the hull on a 1987 F-36 is solid or cored below >the > > water line? > > The Practical Sailor issue that featured the F-30 review said the > > hull was solid below the waterline (on the F-30). I am installing a > > a/c unit and need 2 through hull fittings, one below the water line. > > Also anyone have any tips on installing an A/C Unit. > > I am looking into moving the batteries to under the L-settee area >and > > using the old battery area for the Unit. I wound put it under the V > > berth but a have a 40 gal water tank there. > > Thanks, Dom Venditto > Need a shot of Hank Williams or Patsy Cline? The classic country stars are always singing on MSN Radio Plus. Try one month free!
