Cute note. Thanks. As a semi-newbie, it always
heartens
me to find out some other folks, even you salts, miss
obvious, too. By me, none of it’s obvious yet.
We’ve just “concluded” a glacially speedy rewiring of
whole boat. Six months, 7K. Get out to the San Juans
on
our first two week shakedown cruise. Oops, house bank
o’ batteries seems not to be re-charging while under
motor.
Hmm.
Suffered through. Hunting the occasional non-anchorage
so we could power-up. After a week at home, I noticed
a
bundle of new black cables. One of which appeared to
have
two loose ends. I wonder if this…
Doh.
Now if we could only lure the elusive but highly
popular
marine electrician back to make the nice SeaTalk
Autohelm
stuff talk to all the fancy new Raymarine plotter
stuff. They
seem to be having an “issue.” Work well together
sometimes,
sulk others. Aargh.
Those handy among you, like Sparrow’s prior esteemed
owner,
Sir Brian Guptil, can only wince and imagine. Carry
on, sailors.
Keep the news of your defeegulties coming. It helps me
a bunch.
Mincing regards, MacConnell in Wonderingland
— “William A. Cormack” <wacormack@…> wrote:
Just wanted to share the solution to a problem I
wrote about a few weeks ago.
The problem was that the engine would not turn over
when I tried to use the house batteries but would
with no problem with the starting battery. I could
not understand how this could happen since both
batteries went through the same switch and I
replaced the switch, just in case.
The answer was - look at both sides of the circuit
dummy.
There was a corroded connection in the negative side
where the house bank connected to the common ground.
Low draw loads would work, with some voltage loss,
but the high amperage could not get through the
resistance of the corroded connection.
William A. Cormack, CPA
Principal and Chief Financial Officer
Whelan Associates, LLC, a Corporate Real Estate
Service Firm
100 Faunce Corner Executive Center, Suite 150
500 Faunce Corner Road
North Dartmouth, MA 02747
Voice: 508-984-4100, Fax: 508-984-4101, Cell
508-254-5828
MailTo:wacormack@…
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
