Yesterday I replaced my Milltech AIS receiver with a Comar CSB200 class B transponder. Since we do so many off-shore passages, I wanted to be able to see vessels using AIS and to be seen by the other vessels!
The installation was painless. I already had a second VHF antenna which was shared between a spare VHF radio and the AIS receiver via a VHF splitter. I removed the splitter and ran the antenna directly to the transponder. Should the need arise, I can simply move the VHF antenna from the primary VHF to the backup VHF.
The AIS transponder requires its own GPS antenna. This is required so that you can’t feed it bogus position data. My biggest problem may be that the antenna cable is only 24 feet long, and I think that will be about 2 feet short. I’ll just move the transponder to a closer position. I’m waiting to pull the cable along with a cable for a new WiFi device.
The NMEA output of the AIS transponder goes to a RayMarine C-80 chartplotter, where the AIS vessel data is overlaid on the chart. I went to a neighboring vessel who had an AIS receiver and BlueJacket showed up! Yeah!
The following photo shows a target underway with basic information displayed. In this case it shows the vessel moving 17.2Kts on a course of 185T. The closest point of approach will be 5.25nm and will occur in 51 minutes.
If you ask for detailed information on the target, here’s what you get:
Here’s a photo of radar output with AIS targets overlaid in NY Harbor. Clearly this is an anomaly, but it certainly shows the power:
I’ll be selling my AIS receiver and VHF splitter on eBay sometime soon.
