Posted by katorpus (jrb@…>)
The F40 doesn’t use a topping lift either, and originally came with
soft vangs. The single line lazy jacks hold up the boom.
If you haven’t already done so, replace the upper turning blocks on
the lazy jack system with the “cheekless” kind. These will hang up a
lot LESS than the original Schaefers.
Don’t ease the lazy jacks until after the sail is raised. That way
the sail won’t “fall off” of the boom, and the boom will stay
supported. Release the sheet (or at least ease it several feet) when
hoisting the sail and it will “weathervane” into the wind, making up
for any minor errors in heading as you head into the wind to hoist
the sail(s). I do this all the time, singlehandedly, without benefit
of autopilot or wheel brake… I just reach back and move the wheel a
little (under power) to fix things if the boat starts heading off too
far.
Tighten the lazy jacks before dropping the sail…mark the line where
it runs through the cleat and you’ll know how much to tighten it
initially, and you won’t have to go back and retighten it with the
sails dropped.
When you’re done, move the halyard from the headboard to the end of
the boom and snug it up enough to take some of the pressure off of
the lazy jack lines.
— In FreedomOwnersGroup@yahoogroups.com, “Al Lorman” <ajl@…>
Ron:
The Garhauer rigid vang (or any other brand) does eliminate the
need for a topping lift. On the F30, though, there never was a
topping lift; the lazy jacks were used to hold up the boom.
The Boomkicker is a kind of rigid vang. Not having one, I can’t
compare it to a Garhauer.
Al
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of ron barr
Sent: Thursday, November 08, 2007 7:18 PM
Subject: RE: [FreedomOwnersGroup] Al Lorman & Lazy Jacks
Thanks Al, I’ll see if I can find it… the Garhauer rig
presumably eliminates the topping lift? Is it the same as the
Boomkicker â€" I have forgotten, old age creeping in….
Ron Barr
82 Bridge Street
Newport RI 02840
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Al Lorman
Sent: Thursday, November 08, 2007 2:50 PM
Ron:
I posted a diagram of the revised last jacks in the Files section
of this web site. I installed the cleat with pop rivets. It is at
the aft end so that all adjustments can be made from the cockpit.
Since I do have a Garhauer rigid vang, I only use the lazy jacks to
catch the sail when it comes down.
Al
Sent: Thursday, November 08, 2007 2:23 PM
Subject: [FreedomOwnersGroup] Al Lorman & Lazy Jacks
Al,
Could you possibly send me a photo of your lazy jack set up as
described in your email earlier this year?
I don’t get the advantage of having a cleat at the AFT end of the
boom â€" seems like the wrong place to me, forward is easier to reach
and probably safer.
As I see it the blocks up in the air are ok as long as they don’t
chafe the sail and bang around ie: light â€" but wouldn’t it be
easier to have a couple of lengths of shock cord leading back towards
the mast to hold the lazy jacks forward when the cleat is released
while raising the main. This would get them free of obstructing the
sail and assume the use of a rigid boom vang â€" presumably like the
Garhauer.
Thoughts anyone else??
Ron
Newport RI
