Anchor washdown
Hi,
For my Freedom 32, I have purchased a Simpson Lawrence Sprint 1000 vertical anchor windlass. I had written to the past message board and someone said he had also removed the center bow cleat and installed 1 on port and 1 on the starboard bow and also an anchor washdown. I want to do that also. What I was wondering, was which anchor washdown unit do you recommend, and what size cleats did you use? I have done some research on the washdown units. Would the Shurflo Pro Blaster be the one to go with, and how does the hose mount on the deck or attach to the motor unit? One more thing, would you recommend 200’ feet of HT chain and no rope? I know there are lots of thoughts on the subject. I am in Florida, but hope to leave the dock and go cruising so want to be prepared for that day.
Thanks for any help,
Sward
s/v “Dream On”
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Posted by George E. Herchenroether (g.herk@…>)
The Pro Blaster will do the job…have one that is powerful and reliable. Mount the pump near the intake for your head and splice into that line with a T fitting. Then plumb a line to the deck faucet fitting.
Do you have an anchor locker? That’s where the faucet should be. If not, then I suggest a mounting a faucet in a very protected spot on deck.
200 feet of 5/16 in the bow of a 32 foot boat may overweight the bow. I suggest 100 to 125 feet of 5/16 followed by 200 feet of 1/2 rope. And then have a secondary anchor of different type with a couple hundred feet of rope rode.
-------------------------------------------------------------------------------------------------------George E. Herchenroether ph: 401.847.20284 Bush Street cell: 401.338.5329Newport, RI 02840 email: g.herk@…
Dear George,
Thank you so much for your response to my email question. I happen to be in your area. Am originally from Dartmouth, MA, have spent the summer at the Vineyard and am now in New Beford for some minor surgery, before I get back to my love/my boat in Florida in a couple of weeks. Have to have the work done, because this year I am not able to do any myself due to the surgery.
I do not have an open anchor locker. The chain/rope will go down to the anchor locker through a hole in the deck. There is no opening door/hatch on deck. That’s was one reason for the question about where to put the faucet for the pump.
I had thought that 200 feet of chain might be overkill, but that using the High Test would be lighter weight to compensate. Someone told me that he had the same windlass and that all chain worked best. There are so many trains of thought, it is hard to make a decision.
Thanks again. I thought the 35lb CQR was overkill also, but it came with the boat. I did think maybe I should have another anchor. We’ll see.
-------------------------------------------------------------------------------------------------------George E. Herchenroether ph: 401.847.20284 Bush Street cell: 401.338.5329Newport, RI 02840 email: g.herk@…To unsubscribe from this group, send an email to:freedomyachts2003-unsubscribe@yahoogroups.comYour use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Do you Yahoo!?
