Are Your Holes in Core Epoxied?
Posted by dbwnycl (dbwnycl@…>)
As your boat ages, what discoveries have you made about Freedom/TPI’s
practices regarding epoxying holes in cored areas? For example, are
the holes in the cockpit sole for your pedestal and binacle expoxied?
If not, have you experienced wet core/delamination in that or any
other area that you’ve had to repair?
I replaced the diesel fuel deck fill on my F30 and found that Freedom had simply applied some caulking around the screw holes (yes, screws, not bolts and nuts). There was a little water damage in the core, so I scooped out the core all around the hole and filled with epoxy. The hinges on the cockpit lockers are simply screwed through the cored locker lid. I had to replace about a square foot of soggy core on the larger locker lid.
The pad on which the winches and rope clutches are mounted is solid fiberglass. I replaced one of the deck organizers and found that, while the core was not removed and replaced with epoxy, there was no evidence of any water intrusion (possibly because of the teak block, which provides plenty of area for caulking).
I understand that all holes below the water line are through solid glass.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of dbwnyclSent: Sunday, August 07, 2005 11:31 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Are Your Holes in Core Epoxied?As your boat ages, what discoveries have you made about Freedom/TPI’s practices regarding epoxying holes in cored areas? For example, are the holes in the cockpit sole for your pedestal and binacle expoxied? If not, have you experienced wet core/delamination in that or any other area that you’ve had to repair?IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Coring is the exception and not the norm on the early F36’s. I have
removed, inspected and repaired almost every deck and hull
penetration on my boat. The stanchion, deck fills and rail mounts
around the perimeter of the deck are through a 4" band of solid
glass that comprises the hull/deck joint. The depth sounder is
through solid glass which comprises the seam where the 2 halfs of
the hull were joined. All penetrations in the transom are through
solid glass as the transom is not cored.
Everywhere else, I have looked is balsa cored with backing plates.
Factory installed penetrations have no epoxy core, including High
stress points such as traveler and mainsheet attachment. Fittings
are secured with 5200 and backing plates. The only damage I have
found to date is 2 rotten core areas at hand rail penetrations and 8
sq ft of rotten core around the companionway hatch. I think that
TPI / Freedom relied on the thickness of the fiberglass skins to
resist the crushing loads. For the most part, it worked, but I have
epoxy cored everything regardless.
-– In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.”
Freedom
screws,
so I
The
larger locker lid.
while
evidence
glass.
Al Lorman
F30 Ab Initio
Freedom/TPI’s
are
expoxied?
SPONSORED LINKS
Sailing
<http://groups.yahoo.com/gads?
t=ms&k=Sailing&w1=Sailing&w2=Boating&w3=Bo
ating+magazine&w4=Boating+safety&w5=Caribbean+sailing&w6=Sailing+scho
ols
&c=6&s=112&.sig=5y2gQrBBa0b599QfEWBIow> Boating
t=ms&k=Boating&w1=Sailing&w2=Boating&w3=Bo
ols
&c=6&s=112&.sig=Il2V3gS3qxZ76ad5sF7c-Q> Boating magazine
t=ms&k=Boating+magazine&w1=Sailing&w2=Boat
ing&w3=Boating+magazine&w4=Boating+safety&w5=Caribbean+sailing&w6=Sai
lin
g+schools&c=6&s=112&.sig=yaI6vxHzQl0nzJnES0KDYA>
Boating safety
t=ms&k=Boating+safety&w1=Sailing&w2=Boatin
g&w3=Boating+magazine&w4=Boating+safety&w5=Caribbean+sailing&w6=Saili
ng+
schools&c=6&s=112&.sig=3mccQLfdn_BiZO4BqGBYqQ> Caribbean
sailing
t=ms&k=Caribbean+sailing&w1=Sailing&w2=Boa
ting&w3=Boating+magazine&w4=Boating+safety&w5=Caribbean+sailing&w6=Sa
ili
ng+schools&c=6&s=112&.sig=GDljTi96pVZhrXJvge57Uw> Sailing
schools
t=ms&k=Sailing+schools&w1=Sailing&w2=Boati
ng&w3=Boating+magazine&w4=Boating+safety&w5=Caribbean+sailing&w6=Sail
ing
+schools&c=6&s=112&.sig=A3ObT0hejynpIHOlAU2RpQ>
YAHOO! GROUPS LINKS
Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer
than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter,
Posted by paulsebra (paulsebra@…>)
Good day,
I am rehabbing a 1981 F33 and have found mixed results in TPI’s
diligence … the thru-hulls were okay, but when I moved the fuel
fill from the cockpit floor to the coaming, I had to take out the top
layer of glass and core for an area better then a square foot, because
the cutout for the fuel fill had nothing done to the core around the
hole … as I am a new owner, I don’t know if the fuel fill in the
floor was standard or something the PO cooked up. Any way with the
new fill in the coaming aft of the winch, things are hunky-dory.
Paul
