Auto bilge pump
I was told to leave the bilge pump set to auto. Yesterday when I got there and all day it was running constant with hardly any water in it. I turned it off when I left.Hope I don’t has a wet boat when I go today.I have a float in the new bilge pump. Any advice or ideas? Today I will lift up a little on the float lever.Lola F30
Never miss a thing. Make Yahoo your homepage.
Is the float integrated with the pump or is it separate? Are both the
float and the pump new? It sounds as if either the float is restricted
somehow from returning to its ‘full-down’ position, or something from
the bilge got jammed underneath the float.
On bright star, I replaced the float on the main pump with a solid-
state detector, which I felt worked extremely well. No moving parts to
jam.
Lance
— In FreedomOwnersGroup@yahoogroups.com, Lola Jackson <lolaltd@…>
Lola F30
Posted by ron barr (rwhb@…>)
What make of solid state detector did you get?
Ron
Hoyt F32
Newport RI
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of lance_ryley
Sent: Monday, March 24, 2008 9:27 AM
Subject: [FreedomOwnersGroup] Re: Auto bilge pump
jam.
Lance
Lola F30
I got the $32 West Marine variety, which handles up to a 20amp pump. It
worked very well.
Lance
Ron
Hoyt F32
Newport RI
Thanks Lance- I’ll check that one out.
Ron
Hoyt F32
Newport RI
Sent: Tuesday, March 25, 2008 12:53 PM
worked very well.
Lance
Ron
Hoyt F32
Newport RI
