Barient 8P winches
Hi everybody.
This past summer, the starboard winch parted from the cabin top of my
boat while I was raising my mainsail in the ever-interesting mouth of
the Merrimack River. All the barrel nuts sheared off simultaneously,
leaving four nuts and four washers on the sole of the cabin, and the
winch with a few turns of main halyard jiggling around on a course
for the big drink. Luckily, fate, lightening fast reflexes, and a
functioning cam cleat saved the day.
Now it’s winter time. “Graceful Rose” is wrapped in plastic, and I
have 6 months to fix a few things.
Does anyone have information about how to mount the Barient 8P
winch? I’ve checked the web quickly and only found 10P and other
models. Before I start pulling the thing apart–an activity I suspect
that will be accompanied by lots of little gears and springs flying
around–I figured I’d ask.
Peter
Peter,
check out www.huttonwinches.com and click on servicing your winch.Hope this helps.
Biff
From: Peter Devlin <devlin_peter@…>To: freedom21@yahoogroups.comSent: Saturday, November 22, 2008 4:51:54 PMSubject: [freedom21] Barient 8P winches
Hi everybody.This past summer, the starboard winch parted from the cabin top of my boat while I was raising my mainsail in the ever-interesting mouth of the Merrimack River. All the barrel nuts sheared off simultaneously, leaving four nuts and four washers on the sole of the cabin, and the winch with a few turns of main halyard jiggling around on a course for the big drink. Luckily, fate, lightening fast reflexes, and a functioning cam cleat saved the day.Now it’s winter time. “Graceful Rose” is wrapped in plastic, and I have 6 months to fix a few things. Does anyone have information about how to mount the Barient 8P winch? I’ve checked the web quickly and only found 10P and other models. Before I start pulling the thing apart–an activity I suspect that will be accompanied by lots of little gears and springs flying around–I figured I’d
ask.Thanks,Peter
Hi Peter,
To access F-21’s Barient No 8 Winches:
Put a big screw driver in the winch handle hole and push
down which will release the drum. When you pull it up you will see
the ratchet pawls held in with springs. You will also see the 4
screw holes on the base. CAUTION: Use a towel (or cardboard box)
around the winch so you don’t loose any parts.
Nick
— In freedom21@yahoogroups.com, “Peter Devlin” <devlin_peter@…>
Hi everybody.
my
of
simultaneously,
suspect
Peter
Biff and Nick, Thanks. I figured out the pressing down and
releasing the drum thing. Now at least I can re-mount the winch,
because I can access the screws. As for “servicing/ lubricating” the
other components–we’ll see. I read often about the servicing of
winches, but they seem pretty reliable without a lot of fiddling.
Again, thanks a lot for the helpful and speedy replies.
Peter
In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…> wrote:
Hi Peter,
Nick
— In freedom21@yahoogroups.com, “Peter Devlin” <devlin_peter@>
Hi everybody.
of
my
mouth
of
simultaneously,
course
a
I
suspect
flying
Peter
Posted by Thomas Curran (kaikouravoyager@…>)
Has anyone replaced the 8P with something new and better?
Please see my post about rubrails too
Its freakin cold at the NJ shore
Tom
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…> wrote:
Hi Peter,
Nick
— In freedom21@yahoogroups.com, “Peter Devlin” devlin_peter@
Hi everybody.
my
of
simultaneously,
suspect
Peter
Posted by charles dzwonkowski (cskidwain@…>)
Tom,looking at the albums on the web site I do not believe that Pearson made the freedom with rubber rub rails. You had me wondering and now I thing that I will install them on mine unless I sell the boat before I get to it.Charlie D Red Bank— On Sat, 11/22/08, Thomas Curran <kaikouravoyager@…> wrote:From: Thomas Curran <kaikouravoyager@…>Subject: [freedom21] Re: Barient 8P winchesTo: freedom21@yahoogroups.comDate: Saturday, November 22, 2008, 8:07 PM
Tom
— In freedom21@yahoogrou ps.com, “Nick Marino” <blueraven1@ …> wrote:
Hi Peter,
Nick
— In freedom21@yahoogrou ps.com, “Peter Devlin” devlin_peter@
Hi everybody.
my
of
simultaneously,
suspect
Peter
