Battens
Much should be said of the Freedom “monster roach” main with it’s 5 full battens.
It strives to be “a shape and a way to hold it.” A good sail is wonderful - and needs care.
If your battens are slipping out you need to examine the sail carefully.
Take it down, lay a tarp out on you driveway (as we did) and go over it carefully.
Inspect everything for wear and “tiredness.” Take the battens out of their pockets.
Make sure all slides are in good shape and are lubricated. Try to see if the sail is getting baggy.
Number the battens and replace, tightening them in so well they can’t escape
We ended up replacing the batten pocket slides on Emmylou.
And we have had our local rigger repair a few slight things that help the sail excel.
A bit pricey (to spend on a used sail) but satisfying.
How have you made out?
Sean P. Mulligan
(203) 981-1021
seanpmulligan@…
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Peter DevlinSent: Saturday, June 16, 2007 3:40 PMTo: freedom21@yahoogroups.comSubject: Re: [freedom21] Bravo Skipper!
Hi Sean. It felt great and a little bit intimidating to be out on the high seas. When I raise my main sail, the luff end of the battens sometimes don’t stay in the the little plastic pockets along the luff. This results in the luff of the main not being properly taught. Question: Should the battens be somehow tightened into the plastic brackets—I notice they have screws in them? I have, of course, tied in the battens at the leech. Thanks. Hope you’re well.
PeterSean Mulligan <quadmulligan@yahoo.com> wrote:
How did it feel to be a little boat on the big blue?Peter Devlin <devlin_peter@yahoo.com> wrote:
Comrades,
Yesterday I passed under the 35 foot vertical height span, previously worried about, two times. Once at half tide, and once at high tide. No problems. I also “sailed” “Graceful Rose” in the Atlantic ocean a little east of Newburyport, MA for the first time in my, what was up until then incomplete, life. Good fun, but I have heaps to learn. Henceforth please refer to me as “Skipper”.
Steve <lim@…gov> wrote:
— In freedom21@yahoogroups.com, “Peter Devlin” <devlin_peter@…> wrote:>> I didn’t, despite having intended to, measure the length of my mast > before stepping. Can someone tell me what the distance is from the > water line to the top of the mast. I can do the calculation sort of > geometrically, but would also like a solid number if anyone has one. > Thanks. By the way, the “Graceful Rose” is in the water, pretty much > commissioned, and ready for action. Special thanks to Biff for the > very detailed commissioning and line/“tackle” specs.>The mast height is ~31.5 feet. I ran a measuring tape while it was decommisioned.Steve Lim
Moody friends. Drama queens. Your life? Nope! - their life, your story.Play Sims Stories at Yahoo! Games.
Pinpoint customers who are looking for what you sell.
Posted by Doug Chace (ch47_av8r@…>)
Our second (from the top) batten came out of its plastic guide by the
luff while sailing. It caused the front of the batten sleeve to
tear, and when lowering the sail, the batten got caught on the lazy
jack. Had it been under heavier wind conditions, that could have
caused a problem. But, as it was, I was able to just run the main up
to untangle everything and then lower it all the way.
I agree with Sean, spend the money to get it fixed. It will pay for
itself in less headaches and hassles.
— In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…>
MessageMuch should be said of the Freedom “monster roach” main with
carefully.
over it carefully.
of their pockets.
can’t escape
Sean P. Mulligan
(203) 981-1021
seanpmulligan@…
Peter
Peter Devlin <devlin_peter@…> wrote: Comrades,
as “Skipper”.
Steve <lim@...> wrote:
            --- In <freedom21@yahoogroups.com>,       "Peter
Devlin" <devlin_peter@>
my mast
from the
sort of
has one.
pretty
much
for the
it was
decommisioned.
Steve Lim
your story.
#ygrp-mlmsg { FONT-SIZE: small; FONT-FAMILY:
arial,helvetica,clean,sans-serif}#ygrp-mlmsg TABLE { }#ygrp-mlmsg
SELECT { FONT: 99% arial,helvetica,clean,sans-serif}INPUT {
FONT: 99% arial,helvetica,clean,sans-serif}TEXTAREA { FONT:
99% arial,helvetica,clean,sans-serif}#ygrp-mlmsg PRE { FONT: 100%
monospace}CODE { FONT: 100% monospace}#ygrp-mlmsg * { LINE-
HEIGHT: 1.22em}#ygrp-text { FONT-FAMILY: Georgia}#ygrp-text P {
MARGIN: 0px 0px 1em}#ygrp-tpmsgs { CLEAR: both; FONT-
FAMILY: Arial}#ygrp-vitnav { FONT-SIZE: 77%; MARGIN: 0px; PADDING-
TOP: 10px; FONT-FAMILY: Verdana}#ygrp-vitnav A { PADDING-
RIGHT: 1px; PADDING-LEFT: 1px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px}
#ygrp-actbar { CLEAR: both; MARGIN: 25px 0px; COLOR: #666; WHITE-
SPACE: nowrap; TEXT-ALIGN: right}#ygrp-actbar .left { FLOAT: left;
WHITE-SPACE: nowrap}…bld { FONT-WEIGHT: bold}#ygrp-grft {
PADDING-RIGHT: 0px; PADDING-LEFT: 0px; FONT-SIZE: 77%;
PADDING-BOTTOM: 15px; PADDING-TOP: 15px; FONT-FAMILY:
Verdana}#ygrp-ft { PADDING-RIGHT: 0px; BORDER-TOP: #666 1px
solid; PADDING-LEFT: 0px; FONT-SIZE: 77%; PADDING-BOTTOM: 5px;
PADDING-TOP: 5px; FONT-FAMILY: verdana}#ygrp-mlmsg #logo {
PADDING-BOTTOM: 10px}#ygrp-vital { PADDING-RIGHT: 0px;
PADDING-LEFT: 8px; MARGIN-BOTTOM: 20px; PADDING-BOTTOM: 8px; PADDING-
TOP: 2px; BACKGROUND-COLOR: #e0ecee}#ygrp-vital #vithd { FONT-
WEIGHT: bold; FONT-SIZE: 77%; TEXT-TRANSFORM: uppercase; COLOR: #333;
FONT-FAMILY: Verdana}#ygrp-vital UL { PADDING-RIGHT: 0px; PADDING-
LEFT: 0px; PADDING-BOTTOM: 0px; MARGIN: 2px 0px; PADDING-TOP: 0px}
#ygrp-vital UL LI { CLEAR: both; BORDER-RIGHT: #e0ecee 1px solid;
BORDER-TOP: #e0ecee 1px solid; BORDER-LEFT: #e0ecee 1px solid; BORDER-
BOTTOM: #e0ecee 1px solid; LIST-STYLE-TYPE: none}#ygrp-vital UL
LI .ct { PADDING-RIGHT: 0.5em; FONT-WEIGHT: bold; FLOAT:
right; WIDTH: 2em; COLOR: #ff7900; TEXT-ALIGN: right}#ygrp-vital UL
LI .cat { FONT-WEIGHT: bold}#ygrp-vital A { TEXT-
DECORATION: none}#ygrp-vital A:hover {
TEXT-DECORATION: underline}#ygrp-sponsor #hd { FONT-SIZE:
77%; COLOR: #999}#ygrp-sponsor #ov { PADDING-RIGHT: 13px; PADDING-
LEFT: 13px; MARGIN-BOTTOM: 20px; PADDING-BOTTOM: 6px; PADDING-TOP:
6px; BACKGROUND-COLOR: #e0ecee}#ygrp-sponsor #ov UL { PADDING-
RIGHT: 0px; PADDING-LEFT: 8px; PADDING-BOTTOM: 0px; MARGIN: 0px;
PADDING-TOP: 0px}#ygrp-sponsor #ov LI { PADDING-RIGHT: 0px; PADDING-
LEFT: 0px; FONT-SIZE: 77%; PADDING-BOTTOM: 6px; PADDING-TOP: 6px;
LIST-STYLE-TYPE: square}#ygrp-sponsor #ov LI A { FONT-SIZE:
130%; TEXT-DECORATION: none}#ygrp-sponsor #nc { PADDING-RIGHT: 8px;
PADDING-LEFT: 8px; MARGIN-BOTTOM: 20px; PADDING-BOTTOM: 0px; PADDING-
TOP: 0px; BACKGROUND-COLOR: #eee}#ygrp-sponsor .ad { PADDING-
RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 8px; PADDING-TOP: 8px}
#ygrp-sponsor .ad #hd1 { FONT-WEIGHT: bold; FONT-SIZE: 100%;
COLOR: #628c2a; LINE-HEIGHT: 122%; FONT-FAMILY: Arial}#ygrp-
sponsor .ad A { TEXT-DECORATION: none}#ygrp-sponsor .ad A:hover {
TEXT-DECORATION:
underline}#ygrp-sponsor .ad P { MARGIN: 0px}o { FONT-SIZE:
0px}…MsoNormal { MARGIN: 0px}#ygrp-text TT { FONT-SIZE:
120%}BLOCKQUOTE { MARGIN: 0px 0px 0px 4px}…replbq { }
